SR003HB0G
SR003HB0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-204AL
    DIODE SCHOTTKY 30V 500MA DO204AL
SR003HB0G 数据手册
SR002 – SR010 Taiwan Semiconductor 0.5A, 20V - 100V Schottky Barrier Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Low forward voltage drop Low power loss, high efficiency Guard ring for overvoltage protection High surge current capability RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 0.5 A VRRM 20 - 100 V IFSM 30 A TJ MAX 125, 150 °C APPLICATIONS Package DO-204AL (DO-41) Configuration Single die ● Switching mode power supply (SMPS) ● Adapters ● DC to DC converter MECHANICAL DATA ● ● ● ● ● ● Case: DO-204AL (DO-41) Molding compound meets UL 94V-0 flammability rating Terminal: Pure tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.330g (approximately) DO-204AL (DO-41) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) Repetitive peak reverse voltage VRRM SR 002 SR 002 20 Reverse voltage, total rms value VR(RMS) 14 PARAMETER SYMBOL Marking code on the device SR 003 SR 003 30 SR 004 SR 004 40 SR 005 SR 005 50 SR 006 SR 006 60 SR 009 SR 009 90 21 28 35 42 63 SR UNIT 010 SR 010 100 V 70 V Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature IF 0.5 A IFSM 30 A Storage temperature TSTG TJ -55 to +125 -55 to +150 -55 to +150 1 °C °C Version: H2104 SR002 – SR010 Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJA 50 °C/W Junction-to-ambient thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS (1) Reverse current @ rated VR (2) Junction capacitance SR002 SR003 SR004 SR005 SR006 SR009 SR010 SR002 SR003 SR004 SR006 SR009 SR010 SR002 SR003 SR004 SR005 SR006 SR009 SR010 SR002 SR003 SR004 SR005 SR006 SR009 SR010 SR002 SR003 SR004 SR005 SR006 SR009 SR010 IF = 0.5A, TJ = 25°C SYMBOL VF TYP MAX UNIT - 0.55 V - 0.70 V - 0.85 V - 500 µA - 100 µA - 10 mA - 5 mA - - mA - - mA - - mA - 2 mA 110 - pF 80 - pF 65 - pF TJ = 25°C TJ = 100°C IR TJ = 125°C 1MHz, VR = 4.0V CJ Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING SR0x DO-204AL (DO-41) 5,000 / Tape & Reel SR0x A0G DO-204AL (DO-41) 3,000 / Ammo box SR0xH DO-204AL (DO-41) 5,000 / Tape & Reel SR0xHA0G DO-204AL (DO-41) 3,000 / Ammo box Notes: 1. “x” defines voltage from 20V (SR002) to 100V (SR010) 2. “H” means AEC-Q101 qualified 2 Version: H2104 SR002 – SR010 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 CAPACITANCE (pF) SR005 - SR010 0.5 SR002-SR004 100 SR005-SR010 10 SR002 - SR004 0 f=1.0MHz Vsig=50mVp-p 1 25 50 75 100 125 150 0.1 1 LEAD TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=125°C TJ=75°C 0.01 TJ=25°C 0.001 10 20 30 40 50 60 70 80 90 100 10 10 SR002-SR004 UF1DLW 1 TJ=125°C SR005-SR006 T =25°C J 10.1 SR009-SR010 0.01 Pulse width 300μs 1% duty cycle Pulse width 0.1 0.001 0.20.3 0.4 0.40.6 0.50.8 0.61.0 0.7 1.2 0.8 1.4 0.9 1.6 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 1.8 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 35 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.4 Typical Forward Characteristics 10 0.1 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 1 10 (A) AVERAGE FORWARD CURRENT (A) 1 30 8.3ms single half sine wave 25 20 15 10 5 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: H2104 1.2 SR002 – SR010 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Typical Transient Thermal Characteristics TRANSIENT THERMAL IMPEDANCE (°C/W) 100 10 1 0.1 0.01 0.1 1 10 100 PULSE DURATION (s) 4 Version: H2104 SR002 – SR010 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-204AL (DO-41) MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: H2104 SR002 – SR010 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: H2104
SR003HB0G 价格&库存
很抱歉,暂时无法提供与“SR003HB0G”相匹配的价格&库存,您可以联系我们找货
