UGS5J
Taiwan Semiconductor
CREAT BY ART
5A, 600V Surface Mount Ultra Fast Rectifier
FEATURES
- Ideal for automated placement
- High efficiency, low VF
- High surge current capability
- High reliability
- Low power loss
- Compliant to RoHS Directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
- Halogen-free according to IEC 61249-2-21
2
TO-263AB (D PAK)
MECHANICAL DATA
Case: TO-263AB (D2PAK)
Molding compound: UL flammability classification rating 94V-0
Moisture sensitivity level: level 1, per J-STD-020
Part no. with suffix "H" means AEC-Q101 qualified
Packing code with suffix "G" means green compound (halogen-free)
Terminal: Matte tin plated leads, solderable per JESD22-B102
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.33 g (approximately)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted)
PARAMETER
SYMBOL
UGS5J
UNIT
Maximum repetitive peak reverse voltage
VRRM
600
V
Maximum RMS voltage
VRMS
420
V
Maximum DC blocking voltage
VDC
600
V
Maximum average forward rectified current
IF(AV)
5
A
Peak forward surge current, 8.3 ms single half sine-wave
superimposed on rated load
IFSM
65
A
Maximum instantaneous forward voltage TJ=25°C
IF=5A
TJ=125°C
Maximum reverse current @ rated VR
TJ=25°C
TJ=125°C
Maximum reverse recovery time (Note 1)
Typical thermal resistance
Operating junction temperature range
Storage temperature range
VF
IR
2.0
1.8
V
μA
trr
ns
RθJC
3
°C/W
TJ
- 55 to +150
°C
TSTG
- 55 to +150
°C
Note 1: Test conditions: IF=0.5A, IR=1.0A, IRR=0.25A
Version: B1511
UGS5J
ORDERING INFORMATION
PART NO.
PART NO.
PACKING CODE
SUFFIX
UGS5J
PACKING CODE
SUFFIX
RN
H
PACKAGE
800 / 13" Paper reel
D2PAK
G
MN
PACKING
800 / 13" Plastic reel
*: Optional available
EXAMPLE
EXAMPLE P/N
PART NO.
UGS5JHRNG
UGS5J
PART NO.
SUFFIX
PACKING CODE
PACKING CODE
H
DESCRIPTION
SUFFIX
RN
AEC-Q101 qualified
Green compound
G
RATINGS AND CHARACTERISTICS CURVES
FIG. 2 TYPICAL REVERSE CHARACTERISTICS
FIG.1 FORWARD CURRENT DERATING CURVE
100
INSTANTANEOUS REVERSE CURRENT (μA)
6
AVERAGE FORWARD CURRENT (A)
5
4
3
2
Resistive or
inductive load
with heat sink
1
50
75
100
125
10
TJ=125°C
1
0.1
TJ=25°C
0.01
0.001
FIG. 3 MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
INSTANTANEOUS FORWARD CURRENT (A)
PEAK FORWARD SURGE CURRENT (A)
60
40
8.3ms single half sine wave
NUMBER OF CYCLES AT 60 Hz
60
80
100
120
140
FIG. 4 TYPICAL FORWARD CHARACTERISTICS
80
10
40
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
CASE TEMPERATURE (°C)
1
10
TJ=125°C
1
TJ=25°C
0.1
1
1.2 1.4 1.6 1.8
2
2.2 2.4
FORWARD VOLTAGE (V)
Version: B1511
UGS5J
FIG. 5 TYPICAL JUNCTION CAPACITANCE
CAPACITANCE (pF)
100
10
f=1.0MHz
Vsig=50mVp-p
1
0.1
1
10
100
REVERSE VOLTAGE (V)
PACKAGE OUTLINE DIMENSIONS
2
TO-263AB (D PAK)
DIM.
Unit (mm)
Unit (inch)
Min
Max
Min
Max
A
10.5
0.413
B
14.60
15.88
0.575
0.625
C
2.41
2.67
0.095
0.105
D
0.68
0.94
0.027
0.037
E
2.29
2.79
0.090
0.110
F
4.44
4.70
0.175
0.185
G
1.14
1.40
0.045
0.055
H
1.14
1.40
0.045
0.055
I
8.25
9.25
0.325
0.364
J
0.36
0.53
0.014
0.021
K
2.03
2.79
0.080
0.110
SUGGESTED PAD LAYOUT
Symbol
Unit (mm)
Unit (inch)
A
10.8
0.425
B
8.3
0.327
C
1.1
0.043
D
3.5
0.138
E
16.9
0.665
F
9.5
0.374
G
2.5
0.098
MARKING DIAGRAM
P/N
= Specific Device Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: B1511
UGS5J
CREAT BY ART
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
Version: B1511
很抱歉,暂时无法提供与“UGS5JHMNG”相匹配的价格&库存,您可以联系我们找货
