MUR420S – MUR460S
Taiwan Semiconductor
4A, 200V - 600V Ultra Fast Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Glass passivated chip junction
Ideal for automated placement
Ultra Fast recovery time for high efficiency
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
4
A
VRRM
200 - 600
V
IFSM
75
A
TJ MAX
175
°C
APPLICATIONS
● High frequency rectification
● Freewheeling application
● Switching mode converters and inverters in computer, and
telecommunication
Package
DO-214AB (SMC)
Configuration
Single die
MECHANICAL DATA
Case: DO-214AB (SMC)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.250g (approximately)
DO-214AB (SMC)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
MUR420S
MUR440S
MUR460S
MUR420S
MUR440S
MUR460S
UNIT
Repetitive peak reverse voltage
VRRM
200
400
600
V
Reverse voltage, total rms value
VR(RMS)
140
280
420
V
Forward current
Peak forward surge current, 8.3ms single
half sine-wave superimposed on rated load
Junction temperature
IF
4
A
IFSM
75
A
TJ
- 55 to +175
°C
Storage temperature
TSTG
- 55 to +175
°C
1
Version: F2102
MUR420S – MUR460S
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-ambient thermal resistance
RӨJA
45
°C/W
Junction-to-case thermal resistance
RӨJC
8.5
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
(1)
Reverse current@ rated VR
(2)
MUR420S
MUR440S
MUR460S
MUR420S
MUR440S
MUR460S
MUR420S
MUR440S
MUR460S
MUR420S
MUR440S
MUR460S
Junction capacitance
Reverse recovery time
MUR420S
MUR440S
MUR460S
SYMBOL
IF = 4A, TJ = 25°C
VF
IF = 4A, TJ = 150°C
VF
TJ = 25°C
IR
TJ = 150°C
IR
1MHz, VR = 4.0V
CJ
IF = 0.5A, IR = 1.0A
Irr = 0.25A
trr
TYP
MAX
UNIT
0.875
V
1.250
V
0.710
V
1.050
V
5
μA
10
μA
150
μA
250
μA
65
pF
25
ns
50
ns
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
MUR4xS
DO-214AB (SMC)
3,000 / Tape & Reel
Notes:
1. “x” defines voltage from 200V(MUR420S) to 600V(MUR460S)
2
Version: F2102
MUR420S – MUR460S
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
100
4
CAPACITANCE (pF)
3
2
10
1
f=1.0MHz
Vsig=50mVp-p
1
50
75
100
125
150
0.1
175
1
Fig.4 Typical Forward Characteristics
INSTANTANEOUS FORWARD CURRENT (A)
100
10
TJ=150°C
0.1
TJ=25°C
0.001
10
40
50
60
70
80
90
100
10 10
MUR460S
UF1DLW
1
TJ=150°C
TJ=125°C
TJ=25°C
1
0.1
TJ=25°C
0.01
0.1
0.001
0.3
0.5
0.3
0.4
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Pulse width 300μs
1% duty cycle
Pulse width
0.7
0.5
0.9
1.1
0.6
0.7
0.8
1.3
0.9
1.5
1
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
100
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (μA)
Fig.3 Typical Reverse Characteristics
0.01
100
REVERSE VOLTAGE (V)
CASE TEMPERATURE (°C)
1
10
(A)
AVERAGE FORWARD CURRENT (A)
5
8.3ms single half sine wave
75
50
25
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: F2102
1.2
MUR420S – MUR460S
Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram
4
Version: F2102
MUR420S – MUR460S
PACKAGE OUTLINE DIMENSIONS
DO-214AB (SMC)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Version: F2102
MUR420S – MUR460S
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: F2102
很抱歉,暂时无法提供与“MUR440SHR7G”相匹配的价格&库存,您可以联系我们找货
