SK12H45 A0G
SK12H45 A0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-201AD
    DIODE SCHOTTKY 45V 12A DO201AD
SK12H45 A0G 数据手册
SK12H45 – SK12H60 Taiwan Semiconductor 12A, 45V - 60V Schottky Barrier Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Low forward voltage drop Low power loss, high efficiency Guard ring for overvoltage protection High surge current capability RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS PARAMETER VALUE UNIT IF 12 A VRRM 45 - 60 V IFSM 320 A TJ MAX 175 °C Package DO-201AD Configuration Single die ● Switching mode power supply (SMPS) ● Adapters ● DC to DC converter MECHANICAL DATA ● ● ● ● ● ● Case: DO-201AD Molding compound meets UL 94V-0 flammability rating Terminal: Pure tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 1.30g (approximately) DO-201AD ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device SK12H45 SK12H60 SK12H45 SK12H60 UNIT Repetitive peak reverse voltage VRRM 45 60 V Reverse voltage, total rms value VR(RMS) 31 42 V Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature in DC forward mode IF 12 A IFSM 320 A TJ -55 to +175 ≤ 200 °C Storage temperature TSTG -55 to +175 °C 1 Version: F2105 SK12H45 – SK12H60 Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-ambient thermal resistance RӨJA 30 °C/W Junction-to-case thermal resistance RӨJC 10 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS SK12H45 (1) Reverse current @ rated VR SK12H60 (2) IF = 12A, TJ = 25°C TJ = 25°C SYMBOL VF IR TJ = 100°C TYP MAX UNIT - 0.55 V - 0.70 V - 150 µA - 20 mA Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING SK12Hx DO-201AD 1,250 / Tape & Reel SK12Hx A0G DO-201AD 500 / Ammo box SK12HxH DO-201AD 1,250 / Tape & Reel SK12HxHA0G DO-201AD 500 / Ammo box Notes: 1. "x" defines voltage from 45V (SK12H45) to 60V (SK12H60) 2. “H” means AEC-Q101 qualified 2 Version: F2105 SK12H45 – SK12H60 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 100 12 10 CAPACITANCE (pF) 8 6 4 10 2 0 f=1.0MHz Vsig=50mVp-p 1 25 50 75 100 125 150 175 0.1 1 AMBIENT TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) 1 TJ=125°C 0.1 0.01 TJ=25°C SK12H45 SK12H60 10 20 30 40 50 60 70 80 90 100 100 10 10 UF1DLW 1 SK12H45 TJ=125°C TJ=25°C 0.1 SK12H60 1 0.01 0.1 0.001 0.20.3 Pulse width 300μs 1% duty cycle Pulse width 0.3 0.4 0.4 0.5 0.60.5 0.7 0.60.8 0.7 0.9 10.8 1.1 FORWARD VOLTAGE (V) PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Fig.5 Maximum Non-Repetitive Forward Surge Current 360 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (µA) Fig.4 Typical Forward Characteristics 10 0.0001 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 0.001 10 320 8.3ms single half sine wave 280 240 200 160 120 80 40 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 (A) AVERAGE FORWARD CURRENT (A) 14 Version: F2105 1.2 SK12H45 – SK12H60 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Typical Transient Thermal Characteristics TRANSIENT THERMAL IMPEDANCE (°C/W) 10 1 0.1 0.01 0.1 1 10 100 PULSE DURATION (s) 4 Version: F2105 SK12H45 – SK12H60 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-201AD MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: F2105 SK12H45 – SK12H60 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: F2105
SK12H45 A0G 价格&库存
很抱歉,暂时无法提供与“SK12H45 A0G”相匹配的价格&库存,您可以联系我们找货
