UG1008GHC0G
UG1008GHC0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-220-3
    DIODE ARRAY GP 600V 10A TO220AB
UG1008GHC0G 数据手册
UG1004G – UG1008G Taiwan Semiconductor 10A, 200V - 600V Ultra Fast Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available High efficiency, low VF High current capability High reliability High surge current capability RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS PARAMETER VALUE UNIT IF 10 A VRRM 200 - 600 V IFSM 60 A TJ MAX 150, 175 °C Package TO-220AB Configuration Dual dies ● DC to DC converters ● Switching mode converters and inverters ● Freewheeling application MECHANICAL DATA ● ● ● ● ● ● ● Case: TO-220AB Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Mounting torque: 0.56 N⋅m maximum Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.70g (approximately) TO-220AB ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device Repetitive peak reverse voltage VRRM Reverse voltage, total rms value VR(RMS) UG UG UG UG UG UNIT 1004G 1005G 1006G 1007G 1008G UG UG UG UG UG 1004G 1005G 1006G 1007G 1008G 200 300 400 500 600 V 140 210 280 350 420 V Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature IF 10 A IFSM 60 A TJ -55 to +175 -55 to +150 °C Storage temperature TSTG -55 to +175 -55 to +150 °C 1 Version: B2104 UG1004G – UG1008G Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER Junction-to-case thermal resistance SYMBOL TYP UNIT RӨJC 4 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage per diode CONDITIONS (1) UG1004G UG1005G UG1006G UG1007G UG1008G Reverse current @ rated VR per diode Reverse recovery time (2) UG1004G UG1005G UG1006G UG1007G UG1008G IF = 5A, TJ = 25°C TJ = 25°C SYMBOL VF IR TJ = 125°C IF = 0.5A, IR = 1.0A, Irr = 0.25A TYP MAX UNIT - 0.95 V - 1.25 V - 1.70 V - 10 µA - 100 µA - 22 ns - 30 ns trr Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING UG10xG TO-220AB 50 / Tube UG10xGH TO-220AB 50 / Tube Notes: 1. “x” defines voltage from 200V(UG1004G) to 600V(UG1008G) 2. “H” means AEC-Q101 qualified 2 Version: B2104 UG1004G – UG1008G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 UG1004G - UG1006G 10 CAPACITANCE (pF) 8 6 4 UG1007G - UG1008G 100 2 0 25 50 75 100 125 150 f=1.0MHz Vsig=50mVp-p 10 175 0.1 1 CASE TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=125°C 0.1 0.01 TJ=25°C 0.001 10 20 30 40 50 60 70 80 100 Fig.4 Typical Forward Characteristics 10 90 100 100 10 10 UF1DLW 1 TJ=125°C TJ=125°C TJ=25°C 0.1 0.01 0.1 0.001 0.3 TJ=25°C UG1004G UG1005G-06G UG1007G-08G 1 Pulse width 300μs 1% duty cycle Pulse width 0.3 0.5 0.7 0.9 1.1 1.3 1.5 1.7 0.4 0.5 0.6 0.7 0.8 0.9 1.9 1 1.1 FORWARD VOLTAGE (V) PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Fig.5 Maximum Non-Repetitive Forward Surge Current 80 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (µA) Fig.3 Typical Reverse Characteristics 1 10 REVERSE VOLTAGE (V) (A) AVERAGE FORWARD CURRENT (A) 12 8.3ms single half sine wave 60 40 20 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: B2104 1.2 UG1004G – UG1008G Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS TO-220AB MARKING DIAGRAM 4 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: B2104 UG1004G – UG1008G Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: B2104
UG1008GHC0G 价格&库存
很抱歉,暂时无法提供与“UG1008GHC0G”相匹配的价格&库存,您可以联系我们找货
