ABS20M
Taiwan Semiconductor
2A, 1000V Standard Bridge Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Glass passivated chip junction
Ideal for automated placement
Reliable low cost construction utilizing molded plastic technique
High surge current capability
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
2
A
VRRM
1000
V
IFSM
50
A
TJ MAX
150
°C
Package
ABS
Configuration
Quad
APPLICATIONS
● Switching mode power supply (SMPS)
● Adapters
● Lighting application
MECHANICAL DATA
Case: ABS
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 0.096g (approximately)
ABS
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
ABS20M
UNIT
ABS20M
Repetitive peak reverse voltage
VRRM
1000
V
Reverse voltage, total rms value
VR(RMS)
700
V
1.6
A
2.0
A
50
A
110
A
Forward current
On glass-epoxy
IF
On aluminum substrate
Peak forward surge current, 8.3ms single half sinewave superimposed on rated load
Peak forward surge current, 1.0ms
TJ = 25°C
single half sine-wave superimposed
TJ = 125°C
on rated load
Rating for fusing (t
很抱歉,暂时无法提供与“ABS20M RGG”相匹配的价格&库存,您可以联系我们找货
