3A100HB0G
3A100HB0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-204AC
    DIODE GEN PURP 3A DO204AC
3A100HB0G 数据手册
3A60 – 3A100 Taiwan Semiconductor 3A, 600V - 1000V Standard Rectifier FEATURES ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Glass passivated chip junction High efficiency, Low VF High current capability High surge current capability Low power loss RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 3 A VRRM 600 - 1000 V IFSM 120 A TJ MAX 150 °C Package DO-204AC (DO-15) Configuration Single die APPLICATIONS ● DC to DC converter ● Switching mode converters and inverters ● General purpose MECHANICAL DATA ● ● ● ● ● ● Case: DO-204AC (DO-15) Molding compound meets UL 94V-0 flammability rating Terminal: Pure tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.400g (approximately) DO-204AC (DO-15) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device 3A60 3A100 3A60 3A100 UNIT Repetitive peak reverse voltage VRRM 600 1000 V Reverse voltage, total rms value VR(RMS) 420 700 V Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature IF 3 A IFSM 120 A TJ -55 to +150 °C Storage temperature TSTG -55 to +150 °C 1 Version: B2105 3A60 – 3A100 Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 17 °C/W Junction-to-ambient thermal resistance RӨJA 52 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS Forward voltage (1) Reverse current @ rated VR IF = 3A, TJ = 25°C (2) Junction capacitance TJ = 25°C SYMBOL TYP MAX UNIT VF - 1.1 V - 5 µA - 100 µA 27 - pF IR TJ = 125°C 1MHz, VR = 4.0V CJ Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING 3Ax DO-204AC (DO-15) 3,500 / Tape & Reel 3Ax A0G DO-204AC (DO-15) 1,500 / Ammo box 3AxH DO-204AC (DO-15) 3,500 / Tape & Reel 3AxHA0G DO-204AC (DO-15) 1,500 / Ammo box Notes: 1. "x" defines voltage from 600V (3A60) to 1000V (3A100) 2. “H” means AEC-Q101 qualified 2 Version: B2105 3A60 – 3A100 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 100 3 CAPACITANCE (pF) 2 1 10 f=1.0MHz Vsig=50mVp-p 1 0 25 50 75 100 125 0.1 150 1 LEAD TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=125°C 1 0.1 TJ=25°C 0.01 20 30 40 50 60 70 80 90 100 1010 UF1DLW 1 TJ=125°C TJ=125°C TJ=25°C 10.1 TJ=25°C 0.01 0.1 0.001 0.50.3 0.6 0.4 0.7 0.5 Pulse Pulse width width 300μs 300μs 1% duty cycle Pulse width 0.8 0.6 0.9 0.7 1 0.8 1.1 0.9 11.2 1.1 FORWARD VOLTAGE (V) PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Fig.5 Maximum Non-Repetitive Forward Surge Current 140 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (µA) Fig.4 Typical Forward Characteristics 100 10 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 10 10 (A) AVERAGE FORWARD CURRENT (A) 4 120 8.3ms single half sine wave 100 80 60 40 20 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: B2105 1.2 3A60 – 3A100 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-204AC (DO-15) MARKING DIAGRAM 4 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: B2105 3A60 – 3A100 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: B2105
3A100HB0G 价格&库存
很抱歉,暂时无法提供与“3A100HB0G”相匹配的价格&库存,您可以联系我们找货
