ESDLW – ESJLW
Taiwan Semiconductor
0.8A, 200V - 600V Super Fast Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Glass passivated chip junction
Ideal for automated placement
Low profile package
Low power loss, high efficiency
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
0.8
A
VRRM
200 - 600
V
IFSM
A
TJ MAX
150
°C
APPLICATIONS
Package
SOD-123W
Configuration
Single die
● DC to DC converter
● Switching mode converters and inverters
● Freewheeling application
MECHANICAL DATA
Case: SOD-123W
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.016g (approximately)
SOD-123W
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
ESDLW
ESGLW
ESJLW
ESDLW
ESGLW
ESJLW
UNIT
Repetitive peak reverse voltage
VRRM
200
400
600
V
Reverse voltage, total rms value
VR(RMS)
140
280
420
V
Forward current
Peak forward surge current, 8.3ms single half
sine-wave superimposed on rated load
Junction temperature
IF
0.8
A
IFSM
A
TJ
- 55 to +150
°C
Storage temperature
TSTG
- 55 to +150
°C
1
Version: D2103
ESDLW – ESJLW
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance
RӨJL
34
°C/W
Junction-to-ambient thermal resistance
RӨJA
88
°C/W
Junction-to-case thermal resistance
RӨJC
35
°C/W
Thermal Performance Note: Units mounted on PCB (5mm x 5mm Cu pad test board)
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
ESDLW
Forward voltage
(1)
ESGLW
ESJLW
Reverse current @ rated VR
TYP
MAX
UNIT
IF = 0.4A, TJ = 25°C
0.80
V
IF = 0.8A, TJ = 25°C
0.85
0.95
V
IF = 0.4A, TJ = 125°C
0.65
V
IF = 0.8A, TJ = 125°C
0.72
0.80
V
0.88
V
0.96
1.30
V
0.69
V
0.77
1.05
V
1.03
V
1.14
1.70
V
0.82
V
0.94
1.30
V
1
µA
150
µA
21
pF
pF
19
pF
35
ns
TJ = 25°C
(2)
SYMBOL
VF
IR
TJ = 125°C
ESDLW
Junction capacitance
ESGLW 1MHz, VR = 4.0V
CJ
ESJLW
Reverse recovery time
IF = 0.5A , IR = 1.0A
Irr = 0.25A
trr
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
ESxLW
SOD-123W
10,000 / Tape & Reel
Notes:
1. “x” defines voltage from 200V(ESDLW) to 600V(ESJLW)
2
Version: D2103
ESDLW – ESJLW
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
100
1
0.8
CAPACITANCE (pF) A
0.6
0.4
0.2
f=1.0MHz
Vsig=50mVp-p
1
25
50
75
100
125
150
LEAD TEMPERATURE (°C)
1
10
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
Fig.4 Typical Forward Characteristics
1
INSTANTANEOUS FORWARD CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (μA)
10
ESDLW
TJ=125°C
0.1
0.01
TJ=25°C
0.001
10
40
50
60
70
80
90
10
10
ESDLW
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
UF1DLW
1
TTJ=125°C
J=125°C
1
TJ=25°C
0.1
TJ=25°C
0.01
Pulse width
0.001
0.3
0.1
0.4
100
100
(A)
AVERAGE FORWARD CURRENT (A)
ESDLW
0.4
0.6
0.5
0.6
0.8
Pulse width 300μs
1% duty
0.8
0.9cycle1
1.1
0.7
1
1.2
1.4
FORWARD VOLTAGE (V)
3
Version: D2103
1.2
ESDLW – ESJLW
Fig.5 Typical Junction Capacitance
Fig.6 Typical Reverse Characteristics
100
CAPACITANCE (pF) A
ESGLW
10
f=1.0MHz
Vsig=50mVp-p
1
1
10
10
ESGLW
TJ=125°C
1
0.1
0.01
TJ=25°C
0.001
10
100
40
50
60
70
80
90
100
REVERSE VOLTAGE (V)
10
10
ESGLW
UF1DLW
1
TJ=125°C
TJ=125°C
TJ=25°C
0.1
1
(A)
Fig.7 Typical Forward Characteristics
TJ=25°C
0.01
Pulse width
0.001
0.1
0.3
0.4
0.4
0.6
0.5
0.8
0.6
0.7
1
Pulse width 300μs
1% duty
0.8
0.9 cycle
1
1.1
1.2
1.4
1.2
1.6
FORWARD VOLTAGE (V)
4
Version: D2103
ESDLW – ESJLW
Fig.8 Typical Junction Capacitance
Fig.9 Typical Reverse Characteristics
100
CAPACITANCE (pF)
ESJLW
10
f=1.0MHz
Vsig=50mVp-p
1
1
10
10
ESJLW
TJ=125°C
1
0.1
0.01
TJ=25°C
0.001
10
100
REVERSE VOLTAGE (V)
40
50
60
70
80
90
100
10
10
ESJLW
UF1DLW
1
TJ=125°C
TJ=125°C
0.1
1
TJ=25°C
(A)
Fig.10 Typical Forward Characteristics
TJ=25°C
0.01
Pulse width
0.001
0.1
0.3
0.4
0.4
0.6
0.5
0.8
0.6
1
0.7
1.2
Pulse width 300μs
1% duty
0.8
0.9 cycle1
1.1
1.4
1.6
1.8
1.2
2
FORWARD VOLTAGE (V)
5
Version: D2103
ESDLW – ESJLW
PACKAGE OUTLINE DIMENSIONS
SOD-123W
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
6
P/N
= Marking Code
YW
= Date Code
F
= Factory Code
Version: D2103
ESDLW – ESJLW
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
7
Version: D2103
很抱歉,暂时无法提供与“ESGLWHRQG”相匹配的价格&库存,您可以联系我们找货
