D2SB05 – D2SB80
Taiwan Semiconductor
2A, 50V - 800V Standard Bridge Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Ideal for printed circuit board
High case dielectric strength
High surge current capability
UL Recognized File # E-326243
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
2
A
VRRM
50 - 800
V
IFSM
80
A
TJ MAX
150
°C
Package
GBL
Configuration
Quad
● Switching mode power supply (SMPS)
● Adapters
● Lighting application
MECHANICAL DATA
Case: GBL
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 2.00g (approximately)
GBL
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
D2SB
05
D2SB
10
D2SB
D2SB
40
D2SB
60
D2SB
UNIT
80
D2SB05 D2SB10 D2SB20 D2SB40 D2SB60 D2SB80
Repetitive peak reverse voltage
VRRM
50
100
200
400
600
800
V
Reverse voltage, total rms value
VR(RMS)
35
70
140
280
420
560
V
Forward current
Surge peak forward current, 8.3ms
single half sine-wave superimposed
on rated load
Rating for fusing (t
很抱歉,暂时无法提供与“D2SB10 D2G”相匹配的价格&库存,您可以联系我们找货
