SFF1005GA C0G
SFF1005GA C0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-220-3
    DIODE GEN PURP 300V 10A ITO220AB
SFF1005GA C0G 数据手册
SFF1001G – SFF1008G Taiwan Semiconductor 10A, 50V - 600V Super Fast Rectifier FEATURES ● ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available High efficiency, low VF High current capability High reliability High surge current capability Low power loss UL Recognized File # E-326243 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 10 A VRRM 50 - 600 V IFSM 125 A TJ MAX 150 °C Package ITO-220AB Configuration Dual dies APPLICATIONS ● DC to DC converter ● Switching mode converters and inverters ● Freewheeling application MECHANICAL DATA ● ● ● ● ● ● ● Case: ITO-220AB Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Mounting torque: 0.56 N⋅m maximum Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.70g (approximately) ITO-220AB ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL SFF Marking code on the device Repetitive peak reverse voltage Reverse voltage, total rms value Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature Storage temperature SFF SFF SFF SFF SFF SFF SFF SFF 1001G 1002G 1003G 1004G 1005G 1006G 1007G 1008G SFF SFF SFF SFF SFF SFF UNIT SFF 1001G 1002G 1003G 1004G 1005G 1006G 1007G 1008G VRRM 50 100 150 200 300 400 500 600 V VR(RMS) 35 70 105 140 210 280 350 420 V IF 10 A IFSM 125 A TJ -55 to +150 °C TSTG -55 to +150 °C 1 Version: M2105 SFF1001G – SFF1008G Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJC 2 °C/W Junction-to-case thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL TYP MAX UNIT - 0.975 V - 1.300 V - 1.700 V - 10 µA - 400 µA 70 - pF 50 - pF - 35 ns SFF1001G SFF1002G SFF1003G Forward voltage per diode (1) SFF1004G SFF1005G IF = 5A,TJ = 25°C VF SFF1006G SFF1007G SFF1008G Reverse current @ rated VR per diode (2) TJ = 25°C TJ = 125°C IR SFF1001G SFF1002G SFF1003G Junction capacitance per diode SFF1004G SFF1005G 1MHz, VR = 4.0V CJ SFF1006G SFF1007G SFF1008G Reverse recovery time IF = 0.5A, IR = 1.0A Irr = 0.25A trr Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING SFF10xG ITO-220AB 50 / Tube SFF10xGH ITO-220AB 50 / Tube Notes: 1. “x” defines voltage from 50V(SFF1001G) to 600V(SFF1008G) 2. “H” means AEC-Q101 qualified 2 Version: M2105 SFF1001G – SFF1008G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.2 Typical Junction Capacitance 12 100 10 90 CAPACITANCE (pF) 8 6 4 2 SFF1001G-1004G 80 70 SFF1005G-1008G 60 f=1.0MHz Vsig=50mVp-p 50 0 25 50 75 100 125 40 150 1 10 CASE TEMPERATURE (°C) Fig.4 Typical Forward Characteristics INSTANTANEOUS FORWARD CURRENT (A) 100 TJ=100°C 10 TJ=75°C 1 TJ=25°C 0.1 20 30 40 50 60 70 80 90 100 100 10 SFF1001G-1004G 10 1 UF1DLW SFF1005G-1006G TJ=125°C TJ=25°C 0.1 1 SFF1007G-1008G 0.01 0.1 0.001 0.4 Pulse width 300μs 1% duty cycle Pulse width 0.6 0.8 1.0 1.2 1.4 1.6 1.8 2.0 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1 1.1 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 150 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) Fig.3 Typical Reverse Characteristics 10 100 REVERSE VOLTAGE (V) 125 8.3ms single half sine wave 100 75 50 25 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 (A) AVERAGE FORWARD CURRENT (A) Fig.1 Forward Current Derating Curve Version: M2105 1.2 SFF1001G – SFF1008G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: M2105 SFF1001G – SFF1008G Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS ITO-220AB MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: M2105 SFF1001G – SFF1008G Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: M2105
SFF1005GA C0G 价格&库存
很抱歉,暂时无法提供与“SFF1005GA C0G”相匹配的价格&库存,您可以联系我们找货
