SR1030HC0G
SR1030HC0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-220-3
    DIODE SCHOTTKY 30V 10A TO220AB
SR1030HC0G 数据手册
SR1020 – SR10150 Taiwan Semiconductor 10A, 20V - 150V Schottky Barrier Rectifier FEATURES ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Low power loss, high efficiency Guard ring for overvoltage protection High surge current capability RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● Switching mode power supply (SMPS) ● Adapters ● DC to DC converters PARAMETER VALUE UNIT IF 10 A VRRM 20 - 150 V IFSM 120 A TJ MAX 125, 150 °C Package TO-220AB Configuration Dual dies MECHANICAL DATA ● ● ● ● ● ● ● Case: TO-220AB Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Mounting torque: 0.56 N⋅m maximum Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.80g (approximately) TO-220AB ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) SR SR SR SR SR SR SR SR PARAMETER SYMBOL UNIT 1020 1030 1040 1050 1060 1090 10100 10150 SR SR SR SR SR SR SR SR Marking code on the device 1020 1030 1040 1050 1060 1090 10100 10150 Repetitive peak reverse voltage VRRM 20 30 40 50 60 90 100 150 V Reverse voltage, total rms value Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Critical rate of rise of off-state voltage Junction temperature Storage temperature VR(RMS) 14 21 28 35 42 63 70 105 V IF 10 A IFSM 120 A dv/dt 10,000 V/μs TJ -55 to +125 TSTG -55 to +150 -55 to +150 1 °C °C Version: L2104 SR1020 – SR10150 Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER Junction-to-case thermal resistance SYMBOL TYP UNIT RӨJC 3 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER SR1020 SR1030 SR1040 SR1050 (1) Forward voltage per diode SR1060 SR1090 SR10100 SR10150 SR1020 SR1030 SR1040 SR1050 SR1060 SR1090 SR10100 SR10150 SR1020 SR1030 SR1040 Reverse current @ rated VR per SR1050 (2) diode SR1060 SR1090 SR10100 SR10150 SR1020 SR1030 SR1040 SR1050 SR1060 SR1090 SR10100 SR10150 Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms CONDITIONS IF = 5A, TJ = 25°C SYMBOL VF TYP MAX UNIT - 0.55 V - 0.70 V - 0.85 V - 0.95 V - 500 µA - 100 µA - 10 mA - 5 mA - - mA - - mA - 2 mA TJ = 25°C TJ = 100°C IR TJ = 125°C ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING SR10x TO-220AB 50 / Tube SR10xH TO-220AB 50 / Tube Notes: 1. “x” defines voltage from 20V(SR1020) to 150V(SR10150) 2. “H” means AEC-Q101 qualified 2 Version: L2104 SR1020 – SR10150 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 10000 SR1050 - SR10150 10 CAPACITANCE (pF) 8 6 SR1020 - SR1040 4 1000 2 f=1.0MHz Vsig=50mVp-p 0 25 50 75 100 125 100 150 0.1 1 CASE TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=100°C 1 TJ=25°C 0.01 10 20 30 40 50 60 70 80 100 Fig.4 Typical Forward Characteristics 10 90 100 100 10 SR1050-1060 UF1DLW 1 10 SR1020-1040 TJ=125°C TJ=25°C 0.1 SR10150 1 SR1090-10100 0.01 0.1 0.001 0.1 0.3 Pulse width 300μs 1% duty cycle Pulse width 0.3 0.4 0.5 0.6 0.70.7 0.5 0.9 0.8 0.91.1 1 1.1 FORWARD VOLTAGE (V) PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Fig.5 Maximum Non-Repetitive Forward Surge Current 140 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.3 Typical Reverse Characteristics 0.1 10 REVERSE VOLTAGE (V) (A) AVERAGE FORWARD CURRENT (A) 12 120 8.3ms single half sine wave 100 80 60 40 20 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: L2104 1.2 SR1020 – SR10150 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Typical Transient Thermal Impedance TRANSIENT THERMAL IMPEDANCE (°C/W) 10 1 0.1 0.01 0.1 1 10 100 PULSE DURATION (s) 4 Version: L2104 SR1020 – SR10150 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS TO-220AB MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: L2104 SR1020 – SR10150 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: L2104
SR1030HC0G 价格&库存
很抱歉,暂时无法提供与“SR1030HC0G”相匹配的价格&库存,您可以联系我们找货
