SFS1607GHMNG
SFS1607GHMNG
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-263(D²Pak)
    DIODE GEN PURP 500V 16A TO263AB
SFS1607GHMNG 数据手册
SFS1601G – SFS1608G Taiwan Semiconductor 16A, 50V - 600V Super Fast Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Low forward voltage drop Ideal for automated placement High current capability High surge current capability Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS PARAMETER VALUE UNIT IF 16 A VRRM 50 - 600 V IFSM 125 A TJ MAX 150 °C 2 Package TO-263AB (D PAK) Configuration Dual dies ● DC to DC converter ● Switching mode converters and inverters ● Freewheeling application MECHANICAL DATA ● ● ● ● ● ● 2 Case: TO-263AB (D PAK) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.41g (approximately) 2 TO-263AB (D PAK) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Marking code on the device Repetitive peak reverse voltage Reverse voltage, total rms value Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature Storage temperature SFS SFS SFS SFS SFS SFS SFS SFS SYMBOL 1601 1602 1603 1604 1605 1606 1607 1608 UNIT G G G G G G G G SFS SFS SFS SFS SFS SFS SFS SFS 1601G 1602G 1603G 1604G 1605G 1606G 1607G 1608G VRRM 50 100 150 200 300 400 500 600 V VR(RMS) 35 70 105 140 210 280 350 420 V IF 16 A IFSM 125 A TJ -55 to +150 °C TSTG -55 to +150 °C 1 Version: O2103 SFS1601G – SFS1608G Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJC 2.5 °C/W Junction-to-case thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SFS1601G SFS1602G SFS1603G SFS1604G (1) Forward voltage per diode I = 8A, TJ = 25°C SFS1605G F SFS1606G SFS1607G SFS1608G TJ = 25°C (2) Reverse current @ rated VR per diode TJ = 125°C SFS1601G SFS1602G SFS1603G SFS1604G Junction capacitance per diode SFS1605G 1MHz, VR = 4.0V SFS1606G SFS1607G SFS1608G IF = 0.5A, IR = 1.0A Reverse recovery time Irr = 0.25A Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms SYMBOL TYP MAX UNIT - 0.975 V - 1.300 V - 1.700 V - 10 µA - 400 µA 80 - pF 60 - pF - 35 ns VF IR CJ trr ORDERING INFORMATION ORDERING CODE(1) SFS16xG PACKAGE 2 TO-263AB (D PAK) PACKING 800 / Tape & Reel Notes: 1. “x” defines voltage from 50V(SFS1601G) to 600V(SFS1608G) 2 Version: O2103 SFS1601G – SFS1608G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 100 90 16 CAPACITANCE (pF) 12 8 4 SFS1601G - SFS1604G 80 SFS1605G - SFS1608G 70 60 50 f=1.0MHz Vsig=50mVp-p 40 0 25 50 75 100 125 1 150 10 CASE TEMPERATURE (°C) REVERSE VOLTAGE (V) Fig.4 Typical Forward Characteristics INSTANTANEOUS FORWARD CURRENT (A) 100 TJ=125°C 10 TJ=75°C 1 TJ=25°C 0.1 20 30 40 50 60 70 80 90 100 100 10 SFS1605G - SFS1606G SFS1601G - SFS1604G 10 UF1DLW 1 TJ=125°C TJ=25°C 0.1 1 SFS1607G - SFS1608G 0.01 0.1 0.001 0.4 Pulse width 300μs 1% duty cycle Pulse width 0.3 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 0.6 0.8 1.0 0.4 0.5 0.6 1.2 0.7 1.4 0.8 1.6 0.9 1.8 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 150 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) Fig.3 Typical Reverse Characteristics 10 100 (A) AVERAGE FORWARD CURRENT (A) 20 8.3ms single half sine wave 125 100 75 50 25 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: O2103 1.2 SFS1601G – SFS1608G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: O2103 SFS1601G – SFS1608G Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS 2 TO-263AB (D PAK) SUGGESTED PAD LAYOUT MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: O2103 SFS1601G – SFS1608G Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: O2103
SFS1607GHMNG 价格&库存
很抱歉,暂时无法提供与“SFS1607GHMNG”相匹配的价格&库存,您可以联系我们找货
