SS1H6LW RVG
SS1H6LW RVG
    TAIWANSEMICONDUCTOR(台湾半导体)
    SOD-123W(CFP3)
    电压:60V 电流:1A
SS1H6LW RVG 数据手册
SS1H4LW – SS1H20LW Taiwan Semiconductor 1A, 40V - 200V Schottky Barrier Surface Mount Rectifier FEATURES ● ● ● ● ● ● KEY PARAMETERS Low power loss, high efficiency Ideal for automated placement High surge current capability Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● ● ● ● ● Switching mode power supply (SMPS) Adapters Monitor DC/DC converters TV PARAMETER VALUE UNIT IF 1 A VRRM 40 - 200 V IFSM 30 A TJ MAX 175 °C Package SOD-123W Configuration Single die MECHANICAL DATA ● ● ● ● ● ● Case: SOD-123W Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.016g (approximately) SOD-123W ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device SS1H 4LW SS1H 6LW SS1H 10LW SS1H 15LW SS1H 20LW 1H4LW 1H6LW 1H10LW 1H15LW 1H20LW UNIT Repetitive peak reverse voltage VRRM 40 60 100 150 200 V Reverse voltage, total rms value VR(RMS) 28 42 70 105 140 V Forward current Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load Junction temperature IF 1 A IFSM 30 A TJ - 55 to +175 °C Storage temperature TSTG - 55 to +175 °C 1 Version: C2103 SS1H4LW – SS1H20LW Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 25 °C/W Junction-to-ambient thermal resistance RӨJA 80 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL SS1H4LW SS1H6LW Forward voltage (1) Reverse current @ rated VR Reverse current @ rated VR SS1H10LW SS1H15LW SS1H20LW (2) (2) IF = 1A, TJ = 25°C VF TJ = 25°C SS1H4LW SS1H6LW SS1H10LW TJ = 125°C SS1H15LW SS1H20LW TYP MAX UNIT - 0.65 V - 0.70 V - 0.80 V - 0.85 V - 0.5 µA - 0.3 mA - 0.2 mA - 0.1 mA IR Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING SS1HxLW SOD-123W 10,000 / Tape & Reel Notes: 1. “x” defines voltage from 40V(SS1H4LW) to 200V(SS1H20LW) 2 Version: C2103 SS1H4LW – SS1H20LW Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 SS1H4LW SS1H6LW CAPACITANCE (pF) 1 0 100 SS1H10LW 10 SS1H15LW SS1H20LW f=1.0MHz Vsig=50mVp-p 1 25 50 75 100 125 150 175 0.1 1 LEAD TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=125°C 1 0.1 0.01 TJ=25°C 0.001 10 20 30 40 50 60 70 100 Fig.4 Typical Forward Characteristics 100 80 90 100 10 10 SS1H4LW SS1H6LW UF1DLW 1 TJ=125°C 1 0.1 SS1H15LW T =25°C J SS1H20LW SS1H10LW 0.01 0.1 0.001 0.4 0.5 0.6 0.7 0.3 0.4 0.5 0.6 Pulse width 300μs 1% duty cycle Pulse width 0.8 0.7 0.9 0.8 FORWARD VOLTAGE (V) PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 1.0 0.9 1.1 1 1.1 Fig.5 Maximum Non-Repetitive Forward Surge Current 40 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (uA) Fig.3 Typical Reverse Characteristics 10 10 REVERSE VOLTAGE (V) (A) AVERAGE FORWARD CURRENT (A) 2 8.3ms single half sine wave 30 20 10 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: C2103 1.2 SS1H4LW – SS1H20LW Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS SOD-123W SUGGESTED PAD LAYOUT MARKING DIAGRAM 4 P/N = Marking Code YW = Date Code F = Factory Code Version: C2103 SS1H4LW – SS1H20LW Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: C2103
SS1H6LW RVG 价格&库存
很抱歉,暂时无法提供与“SS1H6LW RVG”相匹配的价格&库存,您可以联系我们找货
SS1H6LW RVG
  • 3000+1.600533000+0.20648
  • 6000+1.465146000+0.18902
  • 9000+1.396159000+0.18012
  • 15000+1.3186315000+0.17012
  • 21000+1.2727221000+0.16420
  • 30000+1.2281030000+0.15844
库存:167
SS1H6LW RVG
  • 1+9.115161+1.17593
  • 10+5.6798610+0.73275
  • 100+3.69464100+0.47664
  • 500+2.84192500+0.36663
  • 1000+2.567131000+0.33118
库存:167
