ABS15J – ABS15M
Taiwan Semiconductor
1.5A, 600V - 1000V Standard Bridge Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Glass passivated chip junction
Ideal for automated placement
Reliable low cost construction utilizing molded plastic technique
High surge current capability
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
1.5
A
VRRM
600 - 1000
V
IFSM
40
A
TJ MAX
150
°C
Package
ABS
Configuration
Quad
APPLICATIONS
● Switching mode power supply (SMPS)
● Adapters
● Lighting application
MECHANICAL DATA
Case: ABS
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 0.096g (approximately)
ABS
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
ABS15J
ABS15M
ABS15J
ABS15M
UNIT
Repetitive peak reverse voltage
VRRM
600
1000
V
Reverse voltage, total rms value
VR(RMS)
420
700
V
Forward current
On glass-epoxy
On aluminum substrate
Surge peak forward current
t = 8.3ms
single half sinewave
t = 1.0ms
superimposed on rated load
Rating for fusing (t
很抱歉,暂时无法提供与“ABS15J REG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1000+2.969691000+0.38421
- 2000+2.709132000+0.35050
- 3000+2.576313000+0.33332
- 5000+2.427055000+0.31401
- 7000+2.338647000+0.30257
- 10000+2.2527210000+0.29145
- 国内价格
- 1+2.07879
- 200+0.82944
- 500+0.80180
- 1000+0.78808
- 国内价格 香港价格
- 1+10.331721+1.33669
- 10+6.4786710+0.83819
- 100+4.24028100+0.54860
- 500+3.27940500+0.42428
