SS1H4LW – SS1H20LW
Taiwan Semiconductor
1A, 40V - 200V Schottky Barrier Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Low power loss, high efficiency
Ideal for automated placement
High surge current capability
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
Switching mode power supply (SMPS)
Adapters
Monitor
DC/DC converters
TV
PARAMETER
VALUE
UNIT
IF
1
A
VRRM
40 - 200
V
IFSM
30
A
TJ MAX
175
°C
Package
SOD-123W
Configuration
Single die
MECHANICAL DATA
Case: SOD-123W
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.016g (approximately)
SOD-123W
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
SS1H
4LW
SS1H
6LW
SS1H
10LW
SS1H
15LW
SS1H
20LW
1H4LW
1H6LW
1H10LW
1H15LW
1H20LW
UNIT
Repetitive peak reverse voltage
VRRM
40
60
100
150
200
V
Reverse voltage, total rms value
VR(RMS)
28
42
70
105
140
V
Forward current
Peak forward surge current,
8.3ms single half sine-wave
superimposed on rated load
Junction temperature
IF
1
A
IFSM
30
A
TJ
- 55 to +175
°C
Storage temperature
TSTG
- 55 to +175
°C
1
Version: C2103
SS1H4LW – SS1H20LW
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance
RӨJL
25
°C/W
Junction-to-ambient thermal resistance
RӨJA
80
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
SS1H4LW
SS1H6LW
Forward voltage
(1)
Reverse current @ rated VR
SS1H10LW
SS1H15LW
SS1H20LW
(2)
(2)
IF = 1A, TJ = 25°C
VF
TJ = 25°C
SS1H4LW
SS1H6LW
SS1H10LW TJ = 125°C
SS1H15LW
SS1H20LW
TYP
MAX
UNIT
0.65
V
0.70
V
0.80
V
0.85
V
0.5
µA
0.3
mA
0.2
mA
0.1
mA
IR
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
SS1HxLW
SOD-123W
10,000 / Tape & Reel
Notes:
1. “x” defines voltage from 40V(SS1H4LW) to 200V(SS1H20LW)
2
Version: C2103
SS1H4LW – SS1H20LW
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1000
SS1H4LW
SS1H6LW
CAPACITANCE (pF)
1
SS1H10LW
10
SS1H15LW
SS1H20LW
f=1.0MHz
Vsig=50mVp-p
1
25
50
75
100
125
150
175
0.1
1
LEAD TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=125°C
1
0.1
0.01
TJ=25°C
0.001
10
40
50
60
70
100
Fig.4 Typical Forward Characteristics
100
80
90
100
10 10
SS1H4LW
SS1H6LW
UF1DLW
1
TJ=125°C
1
0.1
SS1H15LW T =25°C
J
SS1H20LW
SS1H10LW
0.01
0.1
0.001
0.4
0.5
0.6
0.7
0.3
0.4
0.5
0.6
Pulse width 300μs
1% duty cycle
Pulse width
0.8
0.7
0.9
0.8
FORWARD VOLTAGE (V)
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
1.0
0.9
1.1
1
1.1
Fig.5 Maximum Non-Repetitive Forward Surge Current
40
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (uA)
Fig.3 Typical Reverse Characteristics
10
10
REVERSE VOLTAGE (V)
(A)
AVERAGE FORWARD CURRENT (A)
2
8.3ms single half sine wave
30
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: C2103
1.2
SS1H4LW – SS1H20LW
PACKAGE OUTLINE DIMENSIONS
SOD-123W
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
4
P/N
= Marking Code
YW
= Date Code
F
= Factory Code
Version: C2103
SS1H4LW – SS1H20LW
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
5
Version: C2103
很抱歉,暂时无法提供与“SS1H20LW RVG”相匹配的价格&库存,您可以联系我们找货
