1N5819 R1G
1N5819 R1G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-204AL
    DIODE SCHOTTKY 40V 1A DO204AL
1N5819 R1G 数据手册
1N5817 – 1N5819 Taiwan Semiconductor 1A, 20V - 40V Schottky Barrier Rectifier FEATURES ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Low forward voltage drop Guard ring for overvoltage protection High surge current capability RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● Switching mode power supply (SMPS) ● Adapters ● DC to DC converter PARAMETER VALUE UNIT IF 1 A VRRM 20 - 40 V IFSM 30 A TJ MAX 125 °C Package DO-204AL (DO-41) Configuration Single die MECHANICAL DATA ● ● ● ● ● ● Case: DO-204AL (DO-41) Molding compound meets UL 94V-0 flammability rating Terminal: Pure tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.330g (approximately) DO-204AL (DO-41) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device 1N5817 1N5818 1N5819 1N5817 1N5818 1N5819 UNIT Repetitive peak reverse voltage VRRM 20 30 40 V Reverse voltage, total rms value VR(RMS) 14 21 28 V Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Critical rate of rise of off-state voltage IF 1 A IFSM 30 A dv/dt 10,000 V/µs Junction temperature TJ -55 to +125 °C Storage temperature TSTG -55 to +125 °C 1 Version: H2104 1N5817 – 1N5819 Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-ambient thermal resistance RӨJA 100 °C/W Junction-to-case thermal resistance RӨJC 45 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL 1N5817 Forward voltage (1) 1N5818 IF = 1A, TJ = 25°C VF 1N5819 Reverse current @ rated VR (2) Junction capacitance TJ = 25°C IR TJ = 100°C 1MHz, VR = 4.0V CJ TYP MAX UNIT - 0.45 V - 0.55 V - 0.60 V - 1 mA - 10 mA 55 - pF Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING 1N581x DO-204AL (DO-41) 5,000 / Tape & Reel 1N581x A0G DO-204AL (DO-41) 3,000 / Ammo box 1N581xH DO-204AL (DO-41) 5,000 / Tape & Reel 1N581xHA0G DO-204AL (DO-41) 3,000 / Ammo box Notes: 1. “x” defines voltage from 20V (1N5817) to 40V (1N5819) 2. “H” means AEC-Q101 qualified 2 Version: H2104 1N5817 – 1N5819 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 CAPACITANCE (pF) 1 100 10 f=1.0MHz Vsig=50mVp-p 1 0 25 50 75 100 0.1 125 1 LEAD TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=125°C 1 TJ=25°C 0.1 20 30 40 50 60 70 80 90 100 10 10 UF1DLW 1 1N5817 TJ=125°C 1 0.1 TJ=25°C 1N5818-1N5819 0.01 0.1 0.001 0.0 0.3 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Pulse width 300μs 1% duty cycle Pulse width 0.2 0.4 0.4 0.5 0.6 0.8 0.6 0.7 0.8 1.0 0.9 1.2 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 35 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.4 Typical Forward Characteristics 100 10 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 10 10 (A) AVERAGE FORWARD CURRENT (A) 2 30 8.3ms single half sine wave 25 20 15 10 5 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: H2104 1.2 1N5817 – 1N5819 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Typical Transient Thermal Characteristics TRANSIENT THERMAL IMPEDANCE (°C/W) 10 1 0.1 0.01 0.1 1 10 100 PULSE DURATION (s) 4 Version: H2104 1N5817 – 1N5819 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-204AL (DO-41) MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: H2104 1N5817 – 1N5819 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: H2104
1N5819 R1G 价格&库存
很抱歉,暂时无法提供与“1N5819 R1G”相匹配的价格&库存,您可以联系我们找货
