TSF10H100C – TSF10H200C
Taiwan Semiconductor
10A, 100V - 200V Trench Schottky Rectifier
FEATURES
KEY PARAMETERS
Patented Trench Schottky technology
Excellent high temperature stability
Low forward voltage
Low power loss/ high efficiency
High forward surge capability
Compliant RoHS
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
10
A
VRRM
100 - 200
V
IFSM
100
A
TJ MAX
150
°C
Package
ITO-220AB
Configuration
Dual dies
Switching mode power supply (SMPS)
Adapters
Lighting application
On-board DC/DC converter
MECHANICAL DATA
Case: ITO-220AB
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Mounting torque: 0.56 N⋅m maximum
Polarity: As marked
Weight: 1.70g (approximately)
ITO-220AB
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
Repetitive peak reverse voltage
VRRM
Reverse voltage, total rms value
VR(RMS)
TSF10H TSF10H TSF10H TSF10H
UNIT
100C
120C
150C
200C
100C
120C
150C
200C
100
120
150
200
V
70
84
105
140
V
IF
10
A
IFSM
100
A
dv/dt
10,000
V/µs
Junction temperature
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +150
°C
Forward current
Surge peak forward current, 8.3ms single
half sine-wave superimposed on rated load
Critical rate of rise of off-state voltage
1
Version: I2105
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJC
4
°C/W
Junction-to-case thermal resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
TSF10H100C
TSF10H120C
TSF10H150C
Forward voltage per diode
(1)
TSF10H200C
VF
TSF10H100C
TSF10H120C
TSF10H150C
Reverse current @ rated VR
(2)
per diode
IF = 5A, TJ = 25°C
TSF10H200C
TSF10H100C
TSF10H120C
TSF10H150C
TSF10H200C
TSF10H100C
TSF10H120C
TSF10H150C
TSF10H200C
IF = 5A, TJ = 125°C
TJ = 25°C
TYP
MAX
UNIT
0.62
0.70
V
0.66
0.74
V
0.78
0.88
V
0.81
0.91
V
0.55
0.63
V
0.58
0.66
V
0.64
0.72
V
0.67
0.75
V
100
µA
15
mA
10
mA
IR
TJ = 125°C
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
TSF10HxC
ITO-220AB
50 / Tube
Notes:
1. “x” defines voltage from 100V(TSF10H100C) to 200V(TSF10H200C)
2
Version: I2105
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1000
TSF10H100C
10
CAPACITANCE (pF)
8
6
4
100
TSF10H120C
TSF10H150C
10
TSF10H200C
2
f=1.0MHz
Vsig=50mVp-p
1
50
75
100
125
150
0.1
1
CASE TEMPERATURE (°C)
100
10
TJ=150°C
1
TJ=125°C
0.1
TJ=100°C
0.01
0.001
TJ=25°C
0.0001
10
40
50
60
70
80
90 100
100 10
TSF10H100C
10
UF1DLW
1
TJ=150°C
TJ=125°C
T =125°C
J
TJ=25°C
1
TJ=100°C
0.01
0.1
0.001
0.1
Pulse width 300μs
1% duty cycle
Pulse width
0.3
0.3
0.4
INSTANTANEOUS FORWARD CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
TSF10H120C
TJ=150°C
1
TJ=125°C
TJ=100°C
0.01
TJ=25°C
0.0001
10
40
50
60
70
80
0.5
0.6
0.7
0.7
0.8
0.9
0.9
1
1.1
1.1
1.2
1.1
1.2
Fig.6 Typical Forward Characteristics
100
0.001
0.5
FORWARD VOLTAGE (V)
Fig.5 Typical Reverse Characteristics
0.1
TJ=25°C
0.1
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
10
100
Fig.4 Typical Forward Characteristics
Fig.3 Typical Reverse Characteristics
TSF10H100C
10
REVERSE VOLTAGE (V)
(A)
25
90 100
3
100 10
TSF10H120C
10
1
UF1DLW
TJ=150°C
TJ=125°C
TJ=125°C
TJ=25°C
0.1
TJ=25°C
1
TJ=100°C
0.01
0.1
0.1
0.001
0.3
(A)
AVERAGE FORWARD CURRENT (A)
12
Pulse width 300μs
1% duty cycle
Pulse width
0.3
0.4
0.5
0.7
0.9
0.5
0.6
0.7
0.8
0.9
FORWARD VOLTAGE (V)
1.1
1
Version: I2105
1
TJ=125°C
0.1
TJ=100°C
0.01
0.001
TJ=25°C
0.0001
40
50
60
70
80
90 100
100 10
10
TSF10H150C
UF1DLW
1
TJ=150°C
TJT
=125°C
J=125°C
TJ=25°C
0.1
TJ=25°C
1
TJ=100°C
0.01
0.1
0.001
0.2
Pulse width 300μs
1% duty cycle
Pulse width
0.3
0.4
0.4
0.5
0.6
0.6
0.7
0.8
0.8
0.9
1
1.0
FORWARD VOLTAGE (V)
Fig.9 Typical Reverse Characteristics
Fig.10 Typical Forward Characteristics
10
TSF10H200C
1
TJ=150°C
0.1
TJ=125°C
0.01
TJ=100°C
0.001
TJ=25°C
0.0001
10
40
50
60
70
80
90 100
(A)
TJ=150°C
1.1
1.2
1.1
1.2
100 10
TSF10H200C
10
UF1DLW
T =150°C
1
J
TJ=125°C
TJ=125°C
0.1
TJ=25°C
(A)
TSF10H150C
10
10
Fig.8 Typical Forward Characteristics
Fig.7 Typical Reverse Characteristics
TJ=25°C
1
TJ=100°C
0.01
0.1
0.001
0.2
Pulse width 300μs
1% duty cycle
Pulse width
0.3
0.4
0.4
0.5
0.6
0.6
0.8
0.7
0.8
1.0
0.9
1
1.2
FORWARD VOLTAGE (V)
4
Version: I2105
PACKAGE OUTLINE DIMENSIONS
ITO-220AB
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: I2105
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: I2105
很抱歉,暂时无法提供与“TSF10H150C C0G”相匹配的价格&库存,您可以联系我们找货
