SFS1601G – SFS1608G
Taiwan Semiconductor
16A, 50V - 600V Super Fast Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Low forward voltage drop
Ideal for automated placement
High current capability
High surge current capability
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
16
A
VRRM
50 - 600
V
IFSM
125
A
TJ MAX
150
°C
2
Package
TO-263AB (D PAK)
Configuration
Dual dies
● DC to DC converter
● Switching mode converters and inverters
● Freewheeling application
MECHANICAL DATA
2
Case: TO-263AB (D PAK)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.41g (approximately)
2
TO-263AB (D PAK)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Marking code on the device
Repetitive peak reverse
voltage
Reverse voltage, total rms
value
Forward current
Surge peak forward current,
8.3ms single half sine wave
superimposed on rated load
Junction temperature
Storage temperature
SFS SFS SFS SFS SFS SFS
SFS
SFS
SYMBOL 1601 1602 1603 1604 1605 1606 1607 1608 UNIT
G
G
G
G
G
G
G
G
SFS
SFS
SFS
SFS
SFS
SFS
SFS
SFS
1601G 1602G 1603G 1604G 1605G 1606G 1607G 1608G
VRRM
50
100
150
200
300
400
500
600
V
VR(RMS)
35
70
105
140
210
280
350
420
V
IF
16
A
IFSM
125
A
TJ
-55 to +150
°C
TSTG
-55 to +150
°C
1
Version: O2103
SFS1601G – SFS1608G
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJC
2.5
°C/W
Junction-to-case thermal resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SFS1601G
SFS1602G
SFS1603G
SFS1604G
(1)
Forward voltage per diode
I = 8A, TJ = 25°C
SFS1605G F
SFS1606G
SFS1607G
SFS1608G
TJ = 25°C
(2)
Reverse current @ rated VR per diode
TJ = 125°C
SFS1601G
SFS1602G
SFS1603G
SFS1604G
Junction capacitance per diode
SFS1605G 1MHz, VR = 4.0V
SFS1606G
SFS1607G
SFS1608G
IF = 0.5A, IR = 1.0A
Reverse recovery time
Irr = 0.25A
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
SYMBOL
TYP
MAX
UNIT
0.975
V
1.300
V
1.700
V
10
µA
400
µA
80
pF
60
pF
35
ns
VF
IR
CJ
trr
ORDERING INFORMATION
ORDERING CODE(1)
SFS16xG
PACKAGE
2
TO-263AB (D PAK)
PACKING
800 / Tape & Reel
Notes:
1. “x” defines voltage from 50V(SFS1601G) to 600V(SFS1608G)
2
Version: O2103
SFS1601G – SFS1608G
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
100
90
16
CAPACITANCE (pF)
12
8
4
SFS1601G - SFS1604G
80
SFS1605G - SFS1608G
70
60
50
f=1.0MHz
Vsig=50mVp-p
40
50
75
100
125
1
150
10
CASE TEMPERATURE (°C)
REVERSE VOLTAGE (V)
Fig.4 Typical Forward Characteristics
INSTANTANEOUS FORWARD CURRENT (A)
100
TJ=125°C
10
TJ=75°C
1
TJ=25°C
0.1
40
50
60
70
80
90
100
100 10
SFS1605G - SFS1606G
SFS1601G - SFS1604G
10
UF1DLW
1
TJ=125°C
TJ=25°C
0.1
1
SFS1607G - SFS1608G
0.01
0.1
0.001
0.4
Pulse width 300μs
1% duty cycle
Pulse width
0.3
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
0.6
0.8
1.0
0.4
0.5
0.6
1.2
0.7
1.4
0.8
1.6
0.9
1.8
1
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
150
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (μA)
Fig.3 Typical Reverse Characteristics
10
100
(A)
AVERAGE FORWARD CURRENT (A)
125
100
75
50
25
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: O2103
1.2
SFS1601G – SFS1608G
Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram
4
Version: O2103
SFS1601G – SFS1608G
PACKAGE OUTLINE DIMENSIONS
2
TO-263AB (D PAK)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: O2103
SFS1601G – SFS1608G
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: O2103
很抱歉,暂时无法提供与“SFS1603GHMNG”相匹配的价格&库存,您可以联系我们找货
