GBU401 – GBU407
Taiwan Semiconductor
4A, 50V - 1000V Standard Bridge Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Ideal for printed circuit board
High case dielectric strength of 1500VRMS
High surge current capability
UL Recognized File # E-326243
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
4
A
VRRM
50 - 1000
V
IFSM
150
A
TJ MAX
150
°C
Package
GBU
Configuration
Quad
● Switching mode power supply (SMPS)
● Adapters
● Lighting application
MECHANICAL DATA
Case: GBU
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Polarity: As marked
Weight: 4.00g (approximately)
GBU
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
Repetitive peak reverse voltage
VRRM
GBU
401
GBU
401
50
Reverse voltage, total rms value
VR(RMS)
35
PARAMETER
SYMBOL
Marking code on the device
Forward current
Surge peak forward
current, 8.3ms single
half sine-wave
superimposed on
rated load
Surge peak forward
current, 1.0ms single
half sine-wave
superimposed on
rated load
IF
TJ = 25°C
GBU
402
GBU
402
100
GBU
403
GBU
403
200
GBU
404
GBU
404
400
GBU
405
GBU
405
600
GBU
406
GBU
406
800
70
140
280
420
560
GBU
UNIT
407
GBU
407
1000
V
700
V
4
A
150
A
80
A
280
A
260
A
IFSM
TJ = 125°C
TJ = 25°C
IFSM
TJ = 125°C
1
Version: M2103
GBU401 – GBU407
PARAMETER
SYMBOL
GBU
401
GBU
402
GBU
403
GBU
404
GBU
405
GBU
406
GBU
UNIT
407
Rating for fusing (t
很抱歉,暂时无法提供与“GBU402 D2G”相匹配的价格&库存,您可以联系我们找货
