MBR6090PT C0G
MBR6090PT C0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO247
    DIODE ARRAY SCHOTTKY 90V TO247AD
MBR6090PT C0G 数据手册
MBR6035PT – MBR60100PT Taiwan Semiconductor 60A, 35V - 100V Schottky Barrier Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Low power loss, high efficiency Guard ring for overvoltage protection High surge current capability UL Recognized File # E-326243 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● ● ● ● ● PARAMETER VALUE UNIT IF 60 A VRRM 35 - 100 V IFSM 420 A TJ MAX 150 °C Package TO-247AD (TO-3P) Configuration Dual dies Switching mode power supply (SMPS) Adapters Monitor DC to DC converters TV MECHANICAL DATA ● ● ● ● ● ● ● Case: TO-247AD (TO-3P) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Mounting torque: 1.13 N⋅m maximum Polarity: As marked Weight: 6.10g (approximately) TO-247AD (TO-3P) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Marking code on the device Repetitive peak reverse voltage MBR MBR MBR MBR MBR MBR 6045 6050 6060 6090 60100 UNIT SYMBOL 6035 PT PT PT PT PT PT MBR MBR MBR MBR MBR MBR 6035PT 6045PT 6050PT 6060PT 6090PT 60100PT VRRM 35 45 50 60 90 100 V Reverse voltage, total rms value VR(RMS) 24 31 Forward current Surge peak forward current 8.3ms single half sine wave superimposed on rated load Peak repetitive reverse surge (1) current Peak repetitive forward current (Rated VR, Square wave, 20KHz) Critical rate of rise of off-state voltage Notes: 1. tp = 2.0μs, 1.0KHz IF 60 A IFSM 420 A IRRM 1 A IFRM 60 A dV/dt 10,000 V/μs 1 35 42 63 70 V Version: H2103 MBR6035PT – MBR60100PT Taiwan Semiconductor ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL MBR 6035 PT MBR 6045 PT MBR 6050 PT MBR 6060 PT MBR 6090 PT MBR 60100 UNIT PT Junction temperature TJ -55 to +150 °C Storage temperature TSTG -55 to +150 °C THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJC 1.2 °C/W Junction-to-case thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage per diode CONDITIONS (1) Reverse current @ rated VR (2) per diode MBR6035PT MBR6045PT MBR6050PT MBR6060PT MBR6090PT MBR60100PT MBR6035PT MBR6045PT MBR6050PT MBR6060PT MBR6090PT MBR60100PT MBR6035PT MBR6045PT MBR6050PT MBR6060PT MBR6090PT MBR60100PT MBR6035PT MBR6045PT MBR6050PT MBR6060PT MBR6090PT MBR60100PT MBR6035PT MBR6045PT MBR6050PT MBR6060PT MBR6090PT MBR60100PT SYMBOL IF = 30A, TJ = 25°C IF = 60A, TJ = 25°C VF IF = 30A, TJ = 125°C TJ = 25°C TYP MAX UNIT - 0.70 V - 0.75 V - 0.84 V - 0.82 V - 0.93 V - 0.98 V - 0.60 V - 0.65 V - - V - 1000 µA - 30 mA - 20 mA - 10 mA IR TJ = 125°C Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms 2 Version: H2103 MBR6035PT – MBR60100PT Taiwan Semiconductor ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING MBR60xPT TO-247AD (TO-3P) 30 / Tube MBR60xPTH TO-247AD (TO-3P) 30 / Tube Notes: 1. “x” defines voltage from 35V(MBR6035PT) to 100V(MBR60100PT) 2. “H” means AEC-Q101 qualified 3 Version: H2103 MBR6035PT – MBR60100PT Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 10000 6035PT - 6045PT 6050PT - 6060PT 6090PT - 60100PT 60 CAPACITANCE (pF) 45 30 1000 15 f=1.0MHz Vsig=50mVp-p 100 0 25 50 75 100 125 0.1 150 1 CASE TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) 6035PT - 6045PT 6050PT - 60100PT TJ=125°C TJ=75°C 1 0.1 TJ=25°C 0.01 0.001 10 20 30 40 50 60 70 80 90 100 100010 6035PT - 6045PT 6050PT - 60100PT UF1DLW 100 1 TJ=125°C TJ=125°C 10 0.1 TJ=25°C TJ=25°C 1 0.01 0.1 0.001 0.0 0.3 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Pulse width 300μs 1% duty cycle Pulse width 0.2 0.4 0.4 0.5 0.6 0.8 0.6 0.7 0.8 1.0 0.9 1.2 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 480 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.4 Typical Forward Characteristics 1000 10 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 100 10 420 8.3ms single half sine wave 360 300 240 180 120 60 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 4 (A) AVERAGE FORWARD CURRENT (A) 75 Version: H2103 1.2 MBR6035PT – MBR60100PT Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Typical Transient Thermal Impedance TRANSIENT THERMAL IMPEDANCE (°C/W) 10 1 0.1 0.01 0.1 1 10 100 PULSE DURATION (s) 5 Version: H2103 MBR6035PT – MBR60100PT Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS TO-247AD (TO-3P) MARKING DIAGRAM 6 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: H2103 MBR6035PT – MBR60100PT Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 7 Version: H2103
MBR6090PT C0G
物料型号:MBR6035PT – MBR60100PT,由台湾半导体公司生产。
器件简介:这些是60A,35V至100V的肖特基势垒整流器,具有以下特点: - 通过AEC-Q101认证 - 低功耗,高效率 - 防过压保护的护环 - 高浪涌电流能力 - UL认可文件编号E-326243 - 符合RoHS标准 - 根据IEC 61249-2-21无卤素
应用信息:适用于开关电源(SMPS)、适配器、监视器、直流到直流转换器、电视等。
封装信息:封装类型为TO-247AD (TO-3P),封装材料满足UL 94V-0阻燃等级,端子为镀锡铅,可按J-STD-002进行焊接,符合JESD 201类2须测试,最大安装扭矩为1.13 N⋅m,极性按标记,重量约为6.10g。
参数特性:关键参数包括正向电流IF为60A,正向电压VF在30A、25°C时为0.70V(MBR6035PT和MBR6045PT),在60A、25°C时为0.93V(MBR6050PT和MBR6060PT),在额定VR下的反向电流IR在25°C时为1000μA。
引脚分配:文档中提供了引脚分配图,显示了TO-247AD (TO-3P)封装的引脚配置。
功能详解:文档提供了详细的电气规格和热性能参数,例如结到外壳的热阻ReJc为1.2°C/W,以及在不同条件下的正向电压和反向电流的典型值。
绝对最大额定值:包括结温-55至+150°C,存储温度-55至+150°C,重复峰值反向电压VRRM从35V至100V,正向电流IF为60A,浪涌峰值正向电流IFSM为420A等。
特性曲线:文档包含了正向电流降额曲线、典型结电容、典型反向特性、典型正向特性、最大非重复性正向浪涌电流和典型瞬态热阻等图表。
订购信息:提供了订购代码、封装类型和包装信息。
MBR6090PT C0G 价格&库存
很抱歉,暂时无法提供与“MBR6090PT C0G”相匹配的价格&库存,您可以联系我们找货
