SFF1601G – SFF1608G
Taiwan Semiconductor
16A, 50V - 600V Super Fast Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
High efficiency, low VF
High current capability
High reliability
High surge current capability
Low power loss
UL Recognized File # E-326243
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
16
A
VRRM
50 - 600
V
IFSM
125
A
TJ MAX
150
°C
Package
ITO-220AB
Configuration
Dual dies
APPLICATIONS
● DC to DC converter
● Switching mode converters and inverters
● Freewheeling application
MECHANICAL DATA
Case: ITO-220AB
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Mounting torque: 0.56 N⋅m maximum
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.70g (approximately)
ITO-220AB
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
SFF
Marking code on the
device
Repetitive peak reverse
voltage
Reverse voltage,
total rms value
Forward current
Surge peak forward
current, 8.3ms single
half sine wave
superimposed on rated
load
Junction temperature
Storage temperature
SFF
SFF
SFF
SFF
SFF
SFF
SFF
SFF
1601G 1602G 1603G 1604G 1605G 1606G 1607G 1608G
SFF
SFF
SFF
SFF
SFF
SFF
UNIT
SFF
VRRM
50
100
150
200
300
400
500
600
V
VR(RMS)
35
70
105
140
210
280
350
420
V
IF
16
A
IFSM
125
A
TJ
-55 to +150
°C
TSTG
-55 to +150
°C
1
Version: I2105
SFF1601G – SFF1608G
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJC
1.5
°C/W
Junction-to-case thermal resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
TYP
MAX
UNIT
0.975
V
1.300
V
1.700
V
10
µA
400
µA
80
pF
50
pF
35
ns
SFF1601G
SFF1602G
SFF1603G
Forward voltage per diode
(1)
SFF1604G
SFF1605G
IF = 8A,TJ = 25°C
VF
SFF1606G
SFF1607G
SFF1608G
Reverse current @ rated VR per diode
(2)
TJ = 25°C
TJ = 125°C
IR
SFF1601G
SFF1602G
SFF1603G
Junction capacitance per diode
SFF1604G
SFF1605G
1MHz, VR = 4.0V
CJ
SFF1606G
SFF1607G
SFF1608G
Reverse recovery time
IF = 0.5A, IR = 1.0A
Irr = 0.25A
trr
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
SFF16xG
ITO-220AB
50 / Tube
SFF16xGH
ITO-220AB
50 / Tube
Notes:
1. “x” defines voltage from 50V(SFF1601G) to 600V(SFF1608G)
2. “H” means AEC-Q101 qualified
2
Version: I2105
SFF1601G – SFF1608G
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
100
90
16
CAPACITANCE (pF)
12
8
4
SFF1601G-1604G
80
70
SFF1605G-1608G
60
f=1.0MHz
Vsig=50mVp-p
50
25
50
75
100
125
150
1
10
CASE TEMPERATURE (°C)
Fig.4 Typical Forward Characteristics
INSTANTANEOUS FORWARD CURRENT (A)
100
TJ=100°C
10
TJ=75°C
1
TJ=25°C
0.1
40
50
60
70
80
90
100
100 10
SFF1601G-1604G
10
1
UF1DLW
SFF1605G-1606G
TJ=125°C
TJ=25°C
0.1
1
SFF1607G-1608G
0.01
0.1
0.001
0.4
Pulse width 300μs
1% duty cycle
Pulse width
0.3
0.6
0.8
0.4
0.5
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
1.0
0.6
1.2
0.7
1.4
0.8
1.6
0.9
1
1.8
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
150
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (μA)
Fig.3 Typical Reverse Characteristics
10
100
REVERSE VOLTAGE (V)
(A)
AVERAGE FORWARD CURRENT (A)
8.3ms single half sine wave
100
75
50
25
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: I2105
1.2
SFF1601G – SFF1608G
Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram
4
Version: I2105
SFF1601G – SFF1608G
PACKAGE OUTLINE DIMENSIONS
ITO-220AB
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: I2105
SFF1601G – SFF1608G
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: I2105
很抱歉,暂时无法提供与“SFF1604GHC0G”相匹配的价格&库存,您可以联系我们找货
