HER1608PT C0G
HER1608PT C0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO247
    DIODE ARRAY GP 16A TO247AD
HER1608PT C0G 数据手册
HER1601PT – HER1608PT Taiwan Semiconductor 16A, 50V - 1000V High Efficient Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Low forward voltage, high current capability Low thermal resistance Low power loss, high efficiency UL Recognized File # E-326243 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● ● ● ● ● PARAMETER VALUE UNIT IF 16 A VRRM 50 - 1000 V IFSM 200 A TJ MAX 150 °C Package TO-247AD (TO-3P) Configuration Dual dies DC to DC converter Switching mode converters and inverters Lighting application Snubber Freewheeling application MECHANICAL DATA ● ● ● ● ● ● ● Case: TO-247AD (TO-3P) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Mounting torque: 1.13 N⋅m maximum Polarity: As marked Weight: 5.60g (approximately) TO-247AD (TO-3P) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Marking code on the device Repetitive peak reverse voltage Reverse voltage, total rms value Forward current Surge peak forward current 8.3ms single half sine wave superimposed on rated load Junction temperature Storage temperature HER HER HER HER HER HER HER HER SYMBOL 1601 1602 1603 1604 1605 1606 1607 1608 UNIT PT PT PT PT PT PT PT PT HER HER HER HER HER HER HER HER 1601 1602 1603 1604 1605 1606 1607 1608 PT PT PT PT PT PT PT PT VRRM 50 100 200 300 400 600 800 1000 V VR(RMS) 35 70 140 210 280 420 560 700 V IF 16 A IFSM 200 A TJ -55 to +150 °C TSTG -55 to +150 °C 1 Version: H2103 HER1601PT – HER1608PT Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS HER1601PT HER1602PT HER1603PT HER1604PT (1) Forward voltage per diode I = 8A, TJ = 25°C HER1605PT F HER1606PT HER1607PT HER1608PT TJ = 25°C (2) Reverse current @ rated VR per diode TJ = 125°C HER1601PT HER1602PT HER1603PT HER1604PT Junction capacitance per diode 1MHz, VR = 4.0V HER1605PT HER1606PT HER1607PT HER1608PT HER1601PT HER1602PT HER1603PT HER1604PT IF = 0.5A, IR = 1.0A Reverse recovery time HER1605PT Irr = 0.25A HER1606PT HER1607PT HER1608PT Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms SYMBOL VF IR TYP MAX UNIT - 1.0 V - 1.3 V - 1.7 V - 10 µA - 500 µA 85 - pF 60 - pF - 50 ns - 80 ns CJ trr ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING HER16xPT TO-247AD (TO-3P) 30 / Tube HER16xPTH TO-247AD (TO-3P) 30 / Tube Notes: 1. “x” defines voltage from 50V(HER1601PT) to 1000V(HER1608PT) 2. “H” means AEC-Q101 qualified 2 Version: H2103 HER1601PT – HER1608PT Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 1601PT - 1605PT 1606PT - 1608PT 16 14 CAPACITANCE (pF) 12 10 8 6 100 4 f=1.0MHz Vsig=50mVp-p 2 0 10 25 50 75 100 125 150 0.1 1 CASE TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=125°C 10 TJ=25°C 1 20 30 40 50 60 70 80 90 100 100010 100 1 1601PT - 1604PT 1605PT 1606PT - 1608PT UF1DLW TJ=125°C TJ=125°C TJ=25°C 10 0.1 1 0.01 TJ=25°C 0.1 0.001 0.2 0.4 0.6 0.8 0.3 0.4 0.5 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Pulse width 300μs 1% duty cycle Pulse width 1.0 0.6 1.2 1.4 1.6 1.8 2.0 0.7 0.8 0.9 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 250 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) Fig.4 Typical Forward Characteristics 1000 10 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 100 10 8.3ms single half sine wave 200 150 100 50 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 (A) AVERAGE FORWARD CURRENT (A) 18 Version: H2103 1.2 HER1601PT – HER1608PT Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: H2103 HER1601PT – HER1608PT Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS TO-247AD (TO-3P) MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: H2103 HER1601PT – HER1608PT Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: H2103
HER1608PT C0G 价格&库存
很抱歉,暂时无法提供与“HER1608PT C0G”相匹配的价格&库存,您可以联系我们找货
