HER3005PT C0G
HER3005PT C0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO247
    DIODE ARRAY GP 400V 30A TO247AD
HER3005PT C0G 数据手册
HER3001PT – HER3006PT Taiwan Semiconductor 30A, 50V - 600V High Efficient Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Low forward voltage, high current capability Low thermal resistance Low power loss, high efficiency UL Recognized File # E-326243 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● ● ● ● ● PARAMETER VALUE UNIT IF 30 A VRRM 50 - 600 V IFSM 300 A TJ MAX 150 °C Package TO-247AD (TO-3P) Configuration Dual dies DC to DC converter Switching mode converters and inverters Lighting application Snubber Freewheeling application MECHANICAL DATA ● ● ● ● ● ● ● Case: TO-247AD (TO-3P) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Mounting torque: 1.13 N⋅m maximum Polarity: As marked Weight: 5.60g (approximately) TO-247AD (TO-3P) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device Repetitive peak reverse voltage VRRM Reverse voltage, total rms value VR(RMS) HER HER HER HER HER HER 3001 3002 3003 3004 3005 3006 UNIT PT PT PT PT PT PT HER HER HER HER HER HER 3001 3002 3003 3004 3005 3006 PT PT PT PT PT PT 50 100 200 300 400 600 V 35 70 140 210 280 420 V Forward current Surge peak forward current 8.3ms single half sine wave superimposed on rated load Junction temperature IF 30 A IFSM 300 A TJ -55 to +150 °C Storage temperature TSTG -55 to +150 °C 1 Version: I2103 HER3001PT – HER3006PT Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJC 1.4 °C/W Junction-to-case thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage per diode CONDITIONS (1) HER3001PT HER3002PT HER3003PT HER3004PT IF = 15A, TJ = 25°C HER3005PT SYMBOL (2) TJ = 25°C UNIT - 1.0 V - 1.3 V - 1.7 V - 10 µA - 500 µA 175 - pF 145 - pF - 50 ns - 80 ns IR TJ = 125°C HER3001PT HER3002PT HER3003PT Junction capacitance per diode HER3004PT 1MHz, VR = 4.0V HER3005PT CJ HER3006PT Reverse recovery time MAX VF HER3006PT Reverse current @ rated VR per diode TYP HER3001PT HER3002PT HER3003PT I = 0.5A, I = 1.0A F R HER3004PT I = 0.25A HER3005PT rr HER3006PT trr Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING HER30xPT TO-247AD (TO-3P) 30 / Tube HER30xPTH TO-247AD (TO-3P) 30 / Tube Notes: 1. “x” defines voltage from 50V(HER3001PT) to 600V(HER3006PT) 2. “H” means AEC-Q101 qualified 2 Version: I2103 HER3001PT – HER3006PT Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 3001PT - 3005PT 3006PT 30 25 CAPACITANCE (pF) 20 15 10 100 5 0 f=1.0MHz Vsig=50mVp-p 10 25 50 75 100 125 150 0.1 1 CASE TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=125°C 100 10 TJ=25°C 1 30 40 50 60 70 80 90 100 100010 100 1 3001PT - 3004PT 3005PT 3006PT UF1DLW TJ=125°C 10 0.1 TJ=25°C TJ=125°C TJ=25°C 1 0.01 Pulse width 300μs 1% duty cycle Pulse width 0.1 0.001 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 0.3 0.4 0.5 0.6 0.7 0.8 0.9 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 1.8 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 350 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) Fig.4 Typical Forward Characteristics 1000 20 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 10 10 300 8.3ms single half sine wave 250 200 150 100 50 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 (A) AVERAGE FORWARD CURRENT (A) 35 Version: I2103 1.2 HER3001PT – HER3006PT Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: I2103 HER3001PT – HER3006PT Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS TO-247AD (TO-3P) MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: I2103 HER3001PT – HER3006PT Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: I2103
HER3005PT C0G 价格&库存
很抱歉,暂时无法提供与“HER3005PT C0G”相匹配的价格&库存,您可以联系我们找货
