HERF1008GAHC0G
HERF1008GAHC0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-220-3
    DIODE, HIGH EFFICIENT
HERF1008GAHC0G 数据手册
HERF1007GA – HERF1008GA Taiwan Semiconductor 10A, 800V - 1000V High Efficient Rectifier FEATURES ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available High efficiency, low VF High current capability High surge current capability Low power loss UL Recognized File # E-326243 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 10 A VRRM 800 - 1000 V IFSM 125 A TJ MAX 150 °C Package ITO-220AB Configuration Dual dies APPLICATIONS ● DC to DC converter ● Switching mode converters and inverters ● Freewheeling application MECHANICAL DATA ● ● ● ● ● ● ● Case: ITO-220AB Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Mounting torque: 0.56 N⋅m maximum Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.82g (approximately) ITO-220AB ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code onthe device HERF1007GA HERF1008GA HERF1007GA HERF1008GA UNIT Repetitive peak reverse voltage VRRM 800 1000 V Reverse voltage, total rms value VR(RMS) 560 700 V Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature IF 10 A IFSM 125 A TJ -55 to +150 °C Storage temperature TSTG -55 to +150 °C 1 Version: B2105 HERF1007GA – HERF1008GA Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJC 3 °C/W Junction-to-case thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS (1) Forward voltage per diode Reverse current @ rated VR per diode Junction capacitance per diode Reverse recovery time SYMBOL TYP MAX UNIT VF - 1.7 V - 10 µA - 400 µA CJ 40 - pF trr - 80 ns IF = 5A, TJ = 25°C (2) TJ = 25°C TJ = 125°C 1MHz, VR = 4.0V IF = 0.5A , IR = 1.0A Irr = 0.25A IR Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING HERF10xGA ITO-220AB 50 / Tube HERF10xGAH ITO-220AB 50 / Tube Notes: 1. “x” defines voltage from 800V(HERF1007GA) to 1000V(HERF1008GA) 2. “H” means AEC-Q101 qualified 2 Version: B2105 HERF1007GA – HERF1008GA Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 10 CAPACITANCE (pF) 8 6 4 100 10 2 0 25 50 75 100 125 f=1.0MHz Vsig=50mVp-p 1 150 1 10 CASE TEMPERATURE (°C) Fig.4 Typical Forward Characteristics INSTANTANEOUS FORWARD CURRENT (A) 100 TJ=125°C TJ=75°C TJ=25°C 1 10 20 30 40 50 60 70 80 90 100 100 10 10 UF1DLW 1 TJ=125°C TJ=25°C 0.1 1 0.01 0.1 0.001 0.6 0.3 0.80.4 1.0 0.5 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Pulse width 300μs Pulse width 1% duty cycle 1.2 0.6 1.4 0.7 1.6 0.8 1.8 0.9 12.0 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 150 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) Fig.3 Typical Reverse Characteristics 10 100 REVERSE VOLTAGE (V) 125 8.3ms single half sine wave 100 75 50 25 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 (A) AVERAGE FORWARD CURRENT (A) 12 Version: B2105 1.2 HERF1007GA – HERF1008GA Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: B2105 HERF1007GA – HERF1008GA Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS ITO-220AB MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: B2105 HERF1007GA – HERF1008GA Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: B2105
HERF1008GAHC0G 价格&库存
很抱歉,暂时无法提供与“HERF1008GAHC0G”相匹配的价格&库存,您可以联系我们找货
