HERAF1601G – HERAF1606G
Taiwan Semiconductor
16A, 50V - 600V High Efficient Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Glass passivated chip junction
High efficiency, Low VF
High current capability
High reliability
High surge current capability
UL Recognized File # E-326243
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
16
A
VRRM
50 - 600
V
IFSM
250
A
TJ MAX
150
°C
Package
ITO-220AC
Configuration
Single die
APPLICATIONS
● DC to DC converter
● Switching mode converters and inverters
● Freewheeling application
MECHANICAL DATA
Case: ITO-220AC
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Mounting torque: 0.56 N⋅m maximum
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.70g (approximately)
ITO-220AC
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
Repetitive peak reverse voltage
VRRM
Reverse voltage, total rms value
VR(RMS)
HERAF HERAF HERAF HERAF HERAF HERAF
UNIT
1601G 1602G 1603G 1604G 1605G 1606G
50
100
200
300
400
600
V
35
70
140
210
280
420
V
Forward current
Surge peak forward current,
8.3ms single half sine wave
superimposed on rated load
Junction temperature
IF
16
A
IFSM
250
A
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +150
°C
1
Version: K2105
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJC
2
°C/W
Junction-to-case resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
(1)
CONDITIONS
HERAF1601G
HERAF1602G
HERAF1603G
HERAF1604G IF = 16A, TJ = 25°C
HERAF1605G
SYMBOL
Junction capacitance
Reverse recovery time
(2)
TJ = 25°C
TJ = 125°C
HERAF1601G
HERAF1602G
HERAF1603G
HERAF1604G 1MHz, VR = 4.0V
HERAF1605G
HERAF1606G
HERAF1601G
HERAF1602G
HERAF1603G IF = 0.5A, IR = 1.0A
HERAF1604G Irr = 0.25A
HERAF1605G
HERAF1606G
MAX
UNIT
1.0
V
1.3
V
1.7
V
10
µA
400
µA
150
pF
110
pF
50
ns
80
ns
VF
HERAF1606G
Reverse current @ rated VR
TYP
IR
CJ
trr
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
HERAF16xG
ITO-220AC
50 / Tube
HERAF16xGH
ITO-220AC
50 / Tube
Notes:
1. “x” defines voltage from 50V(HERAF1601G) to 600V(HERAF1606G)
2. “H” means AEC-Q101 qualified
2
Version: K2105
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1000
16
HERAF1601G-1005G
CAPACITANCE (pF)
12
8
100
HERAF1606G
10
4
f=1.0MHz
Vsig=50mVp-p
1
25
50
75
100
125
150
1
10
CASE TEMPERATURE (°C)
REVERSE VOLTAGE (V)
Fig.4 Typical Forward Characteristics
INSTANTANEOUS FORWARD CURRENT (A)
1000
TJ=125°C
100
10
TJ=25°C
1
40
50
60
70
80
90
100
100 10
1
HERAF1601G-1604G
UF1DLW
10
TJ=125°C
TJ=25°C
0.1
HERAF1605G
1
0.01
HERAF1606G
0.001
0.1
0.3
0.4
0.5
0.4
0.6
0.8
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Pulse
width
Pulse width
300μs
1% duty cycle
0.6
1
0.7
1.2
0.8
1.4
0.9
1.6
1
1.1
1.8
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
300
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (μA)
Fig.3 Typical Reverse Characteristics
10
100
(A)
AVERAGE FORWARD CURRENT (A)
200
150
100
50
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: K2105
1.2
Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram
4
Version: K2105
PACKAGE OUTLINE DIMENSIONS
ITO-220AC
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: K2105
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: K2105
很抱歉,暂时无法提供与“HERAF1606G C0G”相匹配的价格&库存,您可以联系我们找货
