MBRF10H100CT C0G
MBRF10H100CT C0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-220-3
    DIODE ARRAY SCHOTT 100V ITO220AB
MBRF10H100CT C0G 数据手册
MBRF1035CT – MBRF10200CT Taiwan Semiconductor 10A, 35V - 200V Schottky Barrier Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Low power loss, high efficiency Guard ring for overvoltage protection High surge current capability UL Recognized File # E-326243 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 10 A VRRM 35 - 200 V IFSM 120 A TJ MAX 150 °C APPLICATIONS Package ITO-220AB Configuration Dual dies ● Switching mode power supply (SMPS) ● Adapters ● DC to DC converters MECHANICAL DATA ● ● ● ● ● ● ● Case: ITO-220AB Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Mounting torque: 0.56 N⋅m maximum Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.70g (approximately) ITO-220AB ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) MBRF MBRF MBRF MBRF MBRF MBRF MBRF MBRF PARAMETER SYMBOL 1045 1050 1060 CT CT CT CT 1090 10100 10150 10200 UNIT CT CT CT CT MBRF MBRF MBRF MBRF MBRF MBRF MBRF MBRF 1035 1045 1050 1060 1090 10100 10150 10200 CT CT CT CT CT CT CT CT Marking code on the device Repetitive peak reverse voltage Reverse voltage, total rms value Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Peak repetitive reverse (1) surge current Peak repetitive forward current (Rated VR, Square wave, 20KHz) 1035 VRRM 35 45 50 60 90 100 150 200 V VR(RMS) 24 31 35 42 63 70 105 140 V IF 10 A IFSM 120 A IRRM 0.5 A IFRM 10 A 1 Version: M2105 MBRF1035CT – MBRF10200CT Taiwan Semiconductor ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) MBRF MBRF MBRF MBRF MBRF MBRF MBRF MBRF PARAMETER SYMBOL Critical rate of rise of offstate voltage Junction temperature Storage temperature Notes: 1. tp = 2.0μs, 1.0KHz 1035 1045 1050 1060 CT CT CT CT 1090 10100 10150 10200 UNIT CT CT CT CT dv/dt 10,000 V/µs TJ TSTG -55 to +150 -55 to +150 °C °C THERMAL PERFORMANCE PARAMETER Junction-to-case thermal resistance SYMBOL TYP UNIT RӨJC 3.5 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL MBRF1035CT MBRF1045CT MBRF1050CT MBRF1060CT MBRF1090CT MBRF10150CT MBRF10200CT MBRF1035CT MBRF1045CT MBRF1050CT Forward voltage per diode MBRF1060CT MBRF1090CT IF = 10A,TJ = 25°C MBRF10100CT MBRF10150CT MBRF10200CT MBRF1035CT MBRF1045CT MBRF1050CT MBRF1060CT MBRF1090CT MAX UNIT - 0.70 V - 0.80 V - 0.85 V - 0.88 V - 0.80 V - 0.90 V - 0.95 V - 0.98 V - 0.57 V - 0.65 V - 0.75 V - 0.78 V IF = 5A,TJ = 25°C MBRF10100CT (1) TYP VF IF = 5A,TJ = 125°C MBRF10100CT MBRF10150CT MBRF10200CT 2 Version: M2105 MBRF1035CT – MBRF10200CT Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL MBRF1035CT MBRF1045CT MBRF1050CT Forward voltage per diode (1) MBRF1060CT MBRF1090CT IF = 10A,TJ = 125°C TYP MAX UNIT - 0.67 V - 0.75 V - 0.85 V - 0.88 V - 100 µA - 15 mA - 10 mA - 5 mA VF MBRF10100CT MBRF10150CT MBRF10200CT MBRF1035CT MBRF1045CT MBRF1050CT MBRF1060CT MBRF1090CT TJ = 25°C MBRF10100CT MBRF10150CT Reverse current @ rated VR per diode (2) MBRF10200CT IR MBRF1035CT MBRF1045CT MBRF1050CT MBRF1060CT MBRF1090CT TJ = 125°C MBRF10100CT MBRF10150CT MBRF10200CT Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING MBRF10xCT ITO-220AB 50 / Tube MBRF10xCTH ITO-220AB 50 / Tube Notes: 1. “x” defines voltage from 35V(MBRF1035CT) to 200V(MBRF10200CT) 2. “H” means AEC-Q101 qualified 3 Version: M2105 MBRF1035CT – MBRF10200CT Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 10000 10 CAPACITANCE (pF) 8 6 4 1000 100 2 f=1.0MHz Vsig=50mVp-p 10 0 25 50 75 100 125 0.1 150 CASE TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=125°C 0.1 TJ=75°C 0.01 TJ=25°C 0.001 10 20 30 40 50 60 70 80 10 100 Fig.4 Typical Forward Characteristics 10 90 100 100 10 MBRF1035CT-1045CT 10 1 MBRF1050CT-1060CT UF1DLW TJ=125°C TJ=25°C 0.1 1 MBRF1090CT-10100CT 0.01 0.1 0.001 0.5 MBRF10150CT-10200CT Pulse width 300μs Pulse width 1% duty cycle 0.3 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 0.6 0.7 0.4 0.5 0.8 0.6 0.9 0.7 1.0 0.8 1.1 0.9 1.2 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 135 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.3 Typical Reverse Characteristics 1 1 REVERSE VOLTAGE (V) 120 8.3ms single half sine wave 105 90 75 60 45 30 15 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 4 (A) AVERAGE FORWARD CURRENT (A) 12 Version: M2105 1.2 MBRF1035CT – MBRF10200CT Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Typical Transient Thermal Impedance TRANSIENT THERMAL IMPEDANCE (°C/W) 10 1 0.1 0.01 0.1 1 10 100 PULSE DURATION (s) 5 Version: M2105 MBRF1035CT – MBRF10200CT Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS ITO-220AB MARKING DIAGRAM 6 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: M2105 MBRF1035CT – MBRF10200CT Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 7 Version: M2105
MBRF10H100CT C0G 价格&库存
很抱歉,暂时无法提供与“MBRF10H100CT C0G”相匹配的价格&库存,您可以联系我们找货
