YBS2204G – YBS2207G
Taiwan Semiconductor
2.2A, 400V - 1000V Standard Bridge Rectifier
FEATURES
KEY PARAMETERS
Glass passivated chip junction
Ideal for automated placement
Reliable low cost construction utilizing molded plastic technique
High surge current capability
UL Recognized File # E-326854
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
2.2
A
VRRM
400 - 1000
V
IFSM
90
A
TJ MAX
150
°C
Package
YBS
Configuration
Quad
APPLICATIONS
● Switching mode power supply (SMPS)
● Adapters
● Lighting application
MECHANICAL DATA
Case: YBS
Molding compound meets UL 94V-0 flammability rating
Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 1A whisker test
Polarity: As marked
Weight: 0.220g (approximately)
YBS
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
YBS
YBS
YBS
YBS
2204G
2205G
2206G
2207G
UNIT
YBS2204G YBS2205G YBS2206G YBS2207G
Marking code on the device
Repetitive peak reverse voltage
VRRM
400
600
800
1000
V
Reverse voltage, total rms value
VR(RMS)
280
420
560
700
V
IF
2.2
A
IFSM
90
A
It
2
33.61
As
Junction temperature
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +150
°C
Forward current
Surge peak forward current, 8.3ms single
half sine-wave superimposed on rated load
Rating for fusing (t
很抱歉,暂时无法提供与“YBS2205G RAG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+6.72186
- 5+4.53726
- 25+3.16768
- 47+2.52910
- 128+2.38626
- 1000+2.29384
