TPUH6D – TPUH6J
Taiwan Semiconductor
6A, 200V - 600V Ultra Fast Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Very low profile, typical height of 1.1mm
Excellent high temperature stability
Glass passivated chip junction
Controlled avalanche characteristics
Low leakage current
High forward surge capability
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
6
A
VRRM
200 - 600
V
IFSM
80
A
TJ MAX
175
°C
Package
TO-277A (SMPC)
Configuration
Single die
APPLICATIONS
● DC to DC converter
● Switching mode converters and inverters
● Freewheeling application
MECHANICAL DATA
Case: TO-277A (SMPC)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 1A whisker test
Polarity: Indicated by cathode band
Weight: 0.095g (approximately)
TO-277A (SMPC)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
TPUH6D
TPUH6J
UH6D
UH6J
UNIT
Repetitive peak reverse voltage
VRRM
200
600
V
Reverse voltage, total rms value
VR(RMS)
140
420
V
Forward current
Surge peak forward current, 8.3ms single half
sine wave superimposed on rated load
Junction temperature
IF
6
A
IFSM
80
A
TJ
-55 to +175
°C
Storage temperature
TSTG
-55 to +175
°C
1
Version: D2103
TPUH6D – TPUH6J
THERMAL PERFORMANCE
PARAMETER
Junction-to-lead thermal resistance
SYMBOL
TYP
UNIT
RӨJL
12
°C/W
RӨJA
80
°C/W
(1)
Junction-to-ambient thermal resistance
(2)
Notes:
1. Mounted on FR4 PCB with 16mm x 16mm Cu pad area
2. Free air, mounted on recommended pad
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
TPUH6D
TPUH6J
TPUH6D
Forward voltage
TPUH6J
(1)
TPUH6D
TPUH6J
TPUH6D
TPUH6J
Reverse current @ rated VR
(2)
Junction capacitance
Reverse recovery time
SYMBOL
TYP
MAX
UNIT
0.80
V
1.98
V
0.87
1.05
V
2.45
3.00
V
0.65
V
1.23
V
0.73
0.90
V
1.59
1.80
V
10
µA
200
µA
CJ
50
pF
trr
25
ns
trr
45
ns
IF = 3A, TJ = 25°C
IF = 6A, TJ = 25°C
VF
IF = 3A, TJ = 125°C
IF = 6A, TJ = 125°C
TJ = 25°C
IR
TJ = 125°C
1MHz, VR = 4.0V
IF = 0.5A, IR = 1.0A
Irr = 0.25A
IF = 1A, di/dt = -50A/μs
VR = 30V
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
TPUH6x
TO-277A (SMPC)
6,000 / Tape & Reel
Notes:
1. “x” defines voltage from 200V(TPUH6D) to 600V(TPUH6J)
2
Version: D2103
TPUH6D – TPUH6J
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1000
6
5
CAPACITANCE (pF)
4
3
2
100
1
50
75
100
125
150
f=1.0MHz
Vsig=50mVp-p
10
175
0.1
1
LEAD TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=125°C
0.1
TJ=25°C
0.01
10
40
50
60
70
80
100
Fig.4 Typical Forward Characteristics
10
90
100
100 10
TPUH6J
TPUH6D
UF1DLW
10
1 TJ=125°C
TJ=125°C
TJ=25°C
0.1
1
TJ=25°C
0.01
Pulse width 300μs
1% duty cycle
Pulse width
0.1
0.0 0.3 0.6 0.9 1.2 1.5 1.8 2.1 2.4 2.7 3.0
0.001
0.3
0.4
0.5
0.6
0.7
0.8
0.9
1
1.1
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
100
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (μA)
Fig.3 Typical Reverse Characteristics
1
10
REVERSE VOLTAGE (V)
8.3ms single half sine wave
80
60
40
10
100
NUMBER OF CYCLES AT 60 Hz
3
(A)
AVERAGE FORWARD CURRENT (A)
7
Version: D2103
1.2
TPUH6D – TPUH6J
Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram
4
Version: D2103
TPUH6D – TPUH6J
PACKAGE OUTLINE DIMENSIONS
TO-277A (SMPC)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
P/N
YW
F
5
= Marking Code
= Date Code
= Factory Code
Version: D2103
TPUH6D – TPUH6J
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: D2103
很抱歉,暂时无法提供与“TPUH6J S1G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1500+4.291381500+0.55722
- 4500+3.792894500+0.49249
- 国内价格 香港价格
- 1+14.915261+1.93668
- 10+9.4399310+1.22573
- 50+7.0652350+0.91739
- 100+6.29770100+0.81773
- 500+4.94726500+0.64238
