HER1601PT – HER1608PT
Taiwan Semiconductor
16A, 50V - 1000V High Efficient Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Low forward voltage, high current capability
Low thermal resistance
Low power loss, high efficiency
UL Recognized File # E-326243
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
16
A
VRRM
50 - 1000
V
IFSM
200
A
TJ MAX
150
°C
Package
TO-247AD (TO-3P)
Configuration
Dual dies
DC to DC converter
Switching mode converters and inverters
Lighting application
Snubber
Freewheeling application
MECHANICAL DATA
Case: TO-247AD (TO-3P)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Mounting torque: 1.13 N⋅m maximum
Polarity: As marked
Weight: 5.60g (approximately)
TO-247AD (TO-3P)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Marking code on the device
Repetitive peak reverse
voltage
Reverse voltage, total rms
value
Forward current
Surge peak forward current
8.3ms single half sine wave
superimposed on rated load
Junction temperature
Storage temperature
HER HER HER HER HER HER HER HER
SYMBOL 1601 1602 1603 1604 1605 1606 1607 1608 UNIT
PT
PT
PT
PT
PT
PT
PT
PT
PT
PT
PT
PT
PT
PT
PT
PT
VRRM
50
100
200
300
400
600
800
1000
V
VR(RMS)
35
70
140
210
280
420
560
700
V
IF
16
A
IFSM
200
A
TJ
-55 to +150
°C
TSTG
-55 to +150
°C
1
Version: H2103
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
HER1601PT
HER1602PT
HER1603PT
HER1604PT
(1)
Forward voltage per diode
I = 8A, TJ = 25°C
HER1605PT F
HER1606PT
HER1607PT
HER1608PT
TJ = 25°C
(2)
Reverse current @ rated VR per diode
TJ = 125°C
HER1601PT
HER1602PT
HER1603PT
HER1604PT
Junction capacitance per diode
1MHz, VR = 4.0V
HER1605PT
HER1606PT
HER1607PT
HER1608PT
HER1601PT
HER1602PT
HER1603PT
HER1604PT IF = 0.5A, IR = 1.0A
Reverse recovery time
HER1605PT Irr = 0.25A
HER1606PT
HER1607PT
HER1608PT
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
SYMBOL
VF
IR
TYP
MAX
UNIT
1.0
V
1.3
V
1.7
V
10
µA
500
µA
85
pF
60
pF
50
ns
80
ns
CJ
trr
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
HER16xPT
TO-247AD (TO-3P)
30 / Tube
HER16xPTH
TO-247AD (TO-3P)
30 / Tube
Notes:
1. “x” defines voltage from 50V(HER1601PT) to 1000V(HER1608PT)
2. “H” means AEC-Q101 qualified
2
Version: H2103
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1000
1601PT - 1605PT
1606PT - 1608PT
16
14
CAPACITANCE (pF)
12
10
8
6
100
4
f=1.0MHz
Vsig=50mVp-p
2
25
50
75
100
125
150
0.1
1
CASE TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=125°C
10
TJ=25°C
1
40
50
60
70
80
90
100
100010
100 1
1601PT - 1604PT
1605PT
1606PT
- 1608PT
UF1DLW
TJ=125°C
TJ=125°C
TJ=25°C
10
0.1
1
0.01
TJ=25°C
0.1
0.001
0.2 0.4 0.6 0.8
0.3
0.4
0.5
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Pulse width 300μs
1% duty cycle
Pulse width
1.0
0.6
1.2 1.4 1.6 1.8 2.0
0.7
0.8
0.9
1
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
250
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (μA)
Fig.4 Typical Forward Characteristics
1000
10
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
100
10
200
150
100
50
10
100
NUMBER OF CYCLES AT 60 Hz
3
(A)
AVERAGE FORWARD CURRENT (A)
18
Version: H2103
1.2
Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram
4
Version: H2103
PACKAGE OUTLINE DIMENSIONS
TO-247AD (TO-3P)
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: H2103
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: H2103
很抱歉,暂时无法提供与“HER1603PT C0G”相匹配的价格&库存,您可以联系我们找货
