SRS20150HMNG
SRS20150HMNG
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-263(D²Pak)
    DIODE ARRAY GP 150V 20A TO263AB
SRS20150HMNG 数据手册
SRS2020 – SRS20150 Taiwan Semiconductor 20A, 20V - 150V Schottky Barrier Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Low power loss, high efficiency Ideal for automated placement Guard ring for overvoltage protection High surge current capability Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 20 A VRRM 20 - 150 V IFSM 200 A TJ MAX 125, 150 APPLICATIONS °C 2 Package TO-263AB (D PAK) Configuration Dual dies ● Switching mode power supply (SMPS) ● Adapters ● DC to DC converters MECHANICAL DATA ● ● ● ● ● ● 2 Case: TO-263AB (D PAK) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.37g (approximately) 2 TO-263AB (D PAK) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) Repetitive peak reverse voltage VRRM SRS 2020 SRS 2020 20 Reverse voltage, total rms value VR(RMS) 14 PARAMETER SYMBOL Marking code on the device SRS 2030 SRS 2030 30 SRS 2040 SRS 2040 40 SRS 2050 SRS 2050 50 SRS 2060 SRS 2060 60 21 28 35 42 SRS SRS SRS UNIT 2090 20100 20150 SRS SRS SRS 2090 20100 20150 90 100 150 V 63 70 105 V Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature IF 20 A IFSM 200 A Storage temperature TSTG TJ -55 to +125 -55 to +150 -55 to +150 1 °C °C Version: L2103 SRS2020 – SRS20150 Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJC 1.5 °C/W Junction-to-case thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage per diode CONDITIONS (1) Reverse current @ rated VR (2) per diode SRS2020 SRS2030 SRS2040 SRS2050 SRS2060 SRS2090 SRS20100 SRS20150 SRS2020 SRS2030 SRS2040 SRS2050 SRS2060 SRS2090 SRS20100 SRS20150 SRS2020 SRS2030 SRS2040 SRS2050 SRS2060 SRS2090 SRS20100 SRS20150 SRS2020 SRS2030 SRS2040 SRS2050 SRS2060 SRS2090 SRS20100 SRS20150 IF = 10A, TJ = 25°C SYMBOL VF TYP MAX UNIT - 0.55 V - 0.70 V - 0.92 V - 1.02 V - 500 µA - 100 µA - 15 mA - 10 mA - - mA - - mA - 5 mA TJ = 25°C TJ = 100°C IR TJ = 125°C Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) SRS20x PACKAGE 2 TO-263AB (D PAK) PACKING 800 / Tape & Reel Notes: 1. “x” defines voltage from 20V(SRS2020) to 150V(SRS20150) 2 Version: L2103 SRS2020 – SRS20150 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 10000 SRS2050 - SRS20150 20 CAPACITANCE (pF) 15 SRS2020 - SRS2040 10 SRS2020 - SRS2040 SRS2050 - SRS2060 1000 SRS2090 - SRS20150 5 0 f=1.0MHz Vsig=50mVp-p 100 25 50 75 100 125 150 0.1 CASE TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) 1 0.1 TJ=25°C 0.01 40 50 60 70 80 90 100 1000 10 Pulse width 300μs 1% duty cycle UF1DLW SRS2050 - SRS2060 100 1 10 0.1 SRS2020 - SRS2040 TJ=125°C TJ=25°C 1 0.01 0.1 0.001 0.2 SRS20150 Pulse width SRS2090 - SRS20100 0.3 0.4 0.5 0.3 0.4 0.5 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 0.6 0.7 0.8 0.9 1.0 0.6 0.7 0.8 0.9 1.1 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 250 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) TJ=125°C 30 100 Fig.4 Typical Forward Characteristics 10 20 10 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 10 1 (A) AVERAGE FORWARD CURRENT (A) 25 8.3ms single half sine wave 200 150 100 50 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: L2103 1.2 SRS2020 – SRS20150 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Typical Transient Thermal Impedance TRANSIENT THERMAL IMPEDANCE (°C/W) 10 1 0.1 0.01 0.1 1 10 100 PULSE DURATION (s) 4 Version: L2103 SRS2020 – SRS20150 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS 2 TO-263AB (D PAK) SUGGESTED PAD LAYOUT MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: L2103 SRS2020 – SRS20150 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: L2103
SRS20150HMNG 价格&库存
很抱歉,暂时无法提供与“SRS20150HMNG”相匹配的价格&库存,您可以联系我们找货
