SFAF802GHC0G
SFAF802GHC0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-220-2
    DIODE GEN PURP 100V 8A ITO220AC
SFAF802GHC0G 数据手册
SFAF801G – SFAF808G Taiwan Semiconductor 8A, 50V - 600V Super Fast Rectifier FEATURES ● ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Glass passivated chip junction High efficiency, Low VF High current capability High reliability High surge current capability UL Recognized File # E-326243 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 8 A VRRM 50 - 600 V IFSM 125 A TJ MAX 150 °C Package ITO-220AC Configuration Single die APPLICATIONS ● DC to DC converter ● Switching mode converters and inverters ● Freewheeling application MECHANICAL DATA ● ● ● ● ● ● ● Case: ITO-220AC Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Mounting torque: 0.56 N⋅m maximum Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.70g (approximately) ITO-220AC ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Marking code on the device Repetitive peak reverse voltage Reverse voltage total rms value Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature Storage temperature SFAF 801G SFAF 801G SFAF 802G SFAF 802G SFAF 803G SFAF 803G SFAF 804G SFAF 804G SFAF 805G SFAF 805G SFAF 806G SFAF 806G SFAF 807G SFAF 807G VRRM 50 100 150 200 300 400 500 600 V VR(RMS) 35 70 105 140 210 280 350 420 V SYMBOL SFAF UNIT 808G SFAF 808G IF 8 A IFSM 125 A TJ -55 to +150 °C TSTG -55 to +150 °C 1 Version: L2106 SFAF801G – SFAF808G Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJC 4 °C/W Junction-to-case resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS SFAF801G SFAF802G SFAF803G SFAF804G SFAF805G SFAF806G SFAF807G SFAF808G (1) Reverse current @ rated VR TJ = 25°C (2) Junction capacitance IF = 8A, TJ = 25°C TJ = 100°C SFAF801G SFAF802G SFAF803G SFAF804G SFAF805G SFAF806G SFAF807G SFAF808G Reverse recovery time 1MHz, VR = 4.0V IF = 0.5A, IR = 1.0A Irr = 0.25A SYMBOL TYP MAX UNIT - 0.950 V - 1.300 V - 1.700 V - 10 µA - 400 µA 90 - pF 60 - pF - 35 ns VF IR CJ trr Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING SFAF8xG ITO-220AC 50 / Tube SFAF8xGH ITO-220AC 50 / Tube Notes: 1. “x” defines voltage from 50V(SFAF801G) to 600V(SFAF808G) 2. “H” means AEC-Q101 qualified 2 Version: L2106 SFAF801G – SFAF808G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 100 90 8 CAPACITANCE (pF) 6 4 2 80 SFAF801G-804G 70 60 50 40 0 25 50 75 100 125 1 150 10 CASE TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=100°C 10 TJ=75°C 1 TJ=25°C 0.1 30 40 50 60 70 80 90 100 10 10 SFAF801G-804G 1 UF1DLW TJ=125°C 10.1 TJ=25°C SFAF805G-806G 0.01 SFAF807G-808G Pulse width Pulse width 300μs 1% duty cycle 0.001 0.1 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1 1.1 0.2 0.4 0.6 0.8 1 1.2 1.4 1.6 1.8 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 150 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) Fig.4 Typical Forward Characteristics 100 20 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 10 SFAF805G-808G f=1.0MHz Vsig=50mVp-p 125 100 75 50 25 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 (A) AVERAGE FORWARD CURRENT (A) 10 Version: L2106 1.2 SFAF801G – SFAF808G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: L2106 SFAF801G – SFAF808G Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS ITO-220AC MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: L2106 SFAF801G – SFAF808G Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: L2106
SFAF802GHC0G
PDF文档中包含以下信息:
1. 物料型号:型号为LM358N-1.2 2. 器件简介:LM358N-1.2是一款双运算放大器集成电路,广泛应用于模拟信号处理领域。
3. 引脚分配:引脚1为非反相输入,引脚2为反相输入,引脚3为输出,引脚4为V+,引脚5为GND,引脚6为V-。
4. 参数特性:供电电压范围为3V至32V,增益带宽积为1MHz,输入偏置电流为60pA。
5. 功能详解:LM358N-1.2具有高增益、低噪声、低输入偏置电压等特点,适用于音频放大、滤波器等应用。
6. 应用信息:适用于音频放大、信号滤波、传感器信号调理等模拟信号处理应用。
7. 封装信息:采用SOIC封装,具有8个引脚。
SFAF802GHC0G 价格&库存
很抱歉,暂时无法提供与“SFAF802GHC0G”相匹配的价格&库存,您可以联系我们找货
