RABS15M
Taiwan Semiconductor
1.5A, 1000V Fast Recovery Bridge Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Ideal for automated placement
High surge current capability
Fast reverse recovery time for high frequency
Negligible leakage current
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
1.5
A
VRRM
1000
V
IFSM
50
A
TJ MAX
150
°C
Package
ABS-L
Configuration
Quad
APPLICATIONS
● Switching mode power supply (SMPS)
● Adapters
● Lighting application
MECHANICAL DATA
Case: ABS-L
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 0.090g (approximately)
ABS-L
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
RABS15M
UNIT
RABS15M
Repetitive peak reverse voltage
VRRM
1000
V
Reverse voltage, total rms value
VR(RMS)
700
V
IF
1.5
A
IFSM
50
A
It
2
10
As
Junction temperature
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +150
°C
Forward current
Peak forward surge current, 8.3ms single half sine-wave
superimposed on rated load
Rating for fusing (t
很抱歉,暂时无法提供与“RABS15MHREG”相匹配的价格&库存,您可以联系我们找货
