UGF8JD
Taiwan Semiconductor
8A, 600V Ultra Fast Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
High capability for high di/dt operation.
High surge current capability
UL Recognized File # E-326243
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
● DC to DC converter
● Switching mode converters and inverters
● Freewheeling application
PARAMETER
VALUE
UNIT
IF
8
A
VRRM
600
V
IFSM
100
A
TJ MAX
150
°C
Package
ITO-220AC
Configuration
Single die
MECHANICAL DATA
Case: ITO-220AC
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Mounting torque: 0.56 N⋅m maximum
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.70g (approximately)
ITO-220AC
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
UGF8JD
UNIT
UGF8JD
Repetitive peak revers voltage
VRRM
600
V
Reverse voltage total rms value
VR(RMS)
420
V
Forward current
Surge peak forward current, 8.3ms single half
sine wave superimposed on rated load
Junction temperature
IF
8
A
IFSM
100
A
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +150
°C
1
Version: D2105
UGF8JD
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJC
4
°C/W
Junction-to-case resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
(1)
Reverse current @ rated VR
IF = 8A, TJ = 25°C
(2)
Reverse recovery time
Reverse recovery charges
TJ = 25°C
TJ = 125°C
IF = 0.5A, IR = 1.0A,
Irr = 0.25A
IF = 1A, VR = 30V
dIF/dt = -50A/μs
IF = 1A, VR = 400V
dIF/dt = -200A/μs
TJ = 125°C
SYMBOL
TYP
MAX
UNIT
VF
2.3
V
0.5
µA
100
µA
trr
13
ns
trr
30
ns
Qrr
90
nC
IRM
5
5.5
A
IR
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
UGF8JD
ITO-220AC
50 / Tube
UGF8JDH
ITO-220AC
50 / Tube
Notes:
1. “H” means AEC-Q101 qualified
2
Version: D2105
UGF8JD
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1000
8
CAPACITANCE (pF)
AVERAGE FORWARD CURRENT (A)
10
6
4
100
2
f=1.0MHz
Vsig=50mVp-p
10
50
75
100
125
0.1
150
1
CASE TEMPERATURE (°C)
10
1
TJ=25°C
0.01
40
50
60
70
80
90
100
10 10
1
UF1DLW
TJ=125°C
TJ=125°C
TJ=25°C
10.1
(A)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=125°C
TJ=25°C
0.01
Pulse width 300μs
Pulse width
1% duty cycle
0.001
0.1
0.80.3 1 0.4 1.2 0.51.4 0.61.6 0.71.8 0.82
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
0.9
2.2
12.4 1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
110
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (μA)
Fig.4 Typical Forward Characteristics
100
10
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
0.1
10
100
90
80
70
60
50
40
30
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: D2105
1.2
UGF8JD
PACKAGE OUTLINE DIMENSIONS
ITO-220AC
MARKING DIAGRAM
4
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: D2105
UGF8JD
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
5
Version: D2105
很抱歉,暂时无法提供与“UGF8JD C0G”相匹配的价格&库存,您可以联系我们找货
