HS2MA R3G
HS2MA R3G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-214AC
    DIODE GEN PURP 1KV 1.5A DO214AC
HS2MA R3G 数据手册
HS2AA – HS2MA Taiwan Semiconductor 1.5A, 50V - 1000V High Efficient Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Glass passivated chip junction Ideal for automated placement Low profile package Fast switching for high efficiency Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● ● ● ● ● PARAMETER VALUE UNIT IF 1.5 A VRRM 50 - 1000 V IFSM 50 A TJ MAX 150 °C Package DO-214AC (SMA) Configuration Single die DC to DC converter Switching mode converters and inverters Lighting application Snubber Freewheeling application MECHANICAL DATA ● ● ● ● ● ● Case: DO-214AC (SMA) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.060g (approximately) DO-214AC (SMA) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER HS 2AA HS 2AA HS 2BA HS 2BA HS 2DA HS 2DA HS 2FA HS 2FA HS 2GA HS 2GA HS 2JA HS 2JA HS 2KA HS 2KA VRRM 50 100 200 300 400 600 800 1000 V VR(RMS) 35 70 140 210 280 420 560 700 V SYMBOL Marking code on the device Repetitive peak reverse voltage Reverse voltage, total rms value Forward current Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load Junction temperature Storage temperature HS UNIT 2MA HS 2MA IF 1.5 A IFSM 50 A TJ - 55 to +150 °C TSTG - 55 to +150 °C 1 Version: J2102 HS2AA – HS2MA Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJA 80 °C/W Junction-to-ambient thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS HS2AA HS2BA HS2DA HS2FA HS2GA HS2JA HS2KA HS2MA (1) Reverse current @ rated VR TJ = 25°C (2) Junction capacitance Reverse recovery time IF = 1.5A, TJ = 25°C VF IR TJ = 125°C HS2AA HS2BA HS2DA HS2FA HS2GA HS2JA HS2KA HS2MA HS2AA HS2BA HS2DA HS2FA HS2GA HS2JA HS2KA HS2MA SYMBOL 1MHz, VR = 4.0V IF = 0.5A, IR = 1.0A, Irr = 0.25A TYP MAX UNIT - 1.0 V - 1.3 V - 1.7 V - 5 µA - 100 µA 50 - pF 30 - pF - 50 ns - 75 ns CJ trr Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING HS2xA DO-214AC (SMA) 7,500 / Tape & Reel Notes: 1. “x” defines voltage from 50V(HS2AA) to 1000V(HS2MA) 2 Version: J2102 HS2AA – HS2MA Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 125 100 1.5 CAPACITANCE (pF) 1.0 0.5 75 HS2AA - HS2GA 50 HS2JA - HS2MA 25 f=1.0MHz Vsig=50mVp-p 0 0.0 25 50 75 100 125 0.1 150 1 ° LEAD TEMPERATURE ( °C) INSTANTANEOUS FORWARD CURRENT (A) TJ=125°C 10 TJ=25°C 1 20 30 40 50 60 70 80 90 100 10 10 HS2AA - HS2FA UF1DLW 1 TJ=125°C TJ=25°C HS2GA 10.1 HS2JA - HS2MA 0.01 0.1 0.001 0.6 0.3 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Pulse width 300μs 1% duty cycle Pulse width 0.8 0.4 0.5 1.0 0.6 1.2 0.7 0.8 1.4 0.9 1.6 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 60 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) Fig.4 Typical Forward Characteristics 1000 10 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 100 10 (A) AVERAGE FORWARD CURRENT (A) 2.0 8.3ms single half sine wave 50 40 30 20 10 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: J2102 1.2 HS2AA – HS2MA Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: J2102 HS2AA – HS2MA Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AC (SMA) SUGGESTED PAD LAYOUT MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YW = Date Code F = Factory Code Version: J2102 HS2AA – HS2MA Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: J2102
HS2MA R3G 价格&库存
很抱歉,暂时无法提供与“HS2MA R3G”相匹配的价格&库存,您可以联系我们找货
HS2MA R3G
    • 1+1.08746
    • 200+0.43395
    • 500+0.41948
    • 1000+0.41224
    HS2MA R3G
    • 1+5.363801+0.67289
    • 10+3.3353510+0.41842
    • 100+2.13158100+0.26741
    • 500+1.61125500+0.20214
    库存:1046
