SF62G R0G
SF62G R0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-201AD
    DIODE GEN PURP 100V 6A DO201AD
SF62G R0G 数据手册
SF61G – SF68G Taiwan Semiconductor 6A, 50V - 600V Super Fast Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available High current capability, Low VF High reliability High surge current capability Low power loss RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 6 A VRRM 50 - 600 V IFSM 150 A TJ MAX 150 °C APPLICATIONS Package DO-201AD Configuration Single die ● DC to DC converter ● Switching mode converters and inverters ● Freewheeling application MECHANICAL DATA ● ● ● ● ● ● Case: DO-201AD Molding compound meets UL 94V-0 flammability rating Terminal: Pure tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 1.20g (approximately) DO-201AD ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Marking code on the device Repetitive peak reverse voltage Reverse voltage, total rms value Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature Storage temperature SF 61G SF 61G SF 62G SF 62G SF 63G SF 63G SF 64G SF 64G SF 65G SF 65G SF 66G SF 66G SF 67G SF 67G SF UNIT 68G SF 68G VRRM 50 100 150 200 300 400 500 600 V VR(RMS) 35 70 105 140 210 280 350 420 V SYMBOL IF 6 A IFSM 150 A TJ -55 to +150 °C TSTG -55 to +150 °C 1 Version: G2105 SF61G – SF68G Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 5 °C/W Junction-to-ambient thermal resistance RӨJA 40 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS SF61G SF62G SF63G SF64G SF65G SF66G SF67G SF68G (1) Reverse current @ rated VR TJ = 25°C (2) Junction capacitance IF = 6A, TJ = 25°C Reverse recovery time 1MHz, VR = 4.0V IF = 0.5A, IR = 1.0A, Irr = 0.25A TYP MAX UNIT - 0.975 V - 1.300 V - 1.700 V - 5 µA - 100 µA 100 - pF 50 - pF - 35 ns VF IR TJ = 125°C SF61G SF62G SF63G SF64G SF65G SF66G SF67G SF68G SYMBOL CJ trr Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING SF6xG DO-201AD 1,250 / Tape & Reel SF6xG A0G DO-201AD 500 / Ammo box SF6xGH DO-201AD 1,250 / Tape & Reel SF6xGHA0G DO-201AD 500 / Ammo box Notes: 1. "x" defines voltage from 50V (SF61G) to 600V (SF68G) 2. “H” means AEC-Q101 qualified 2 Version: G2105 SF61G – SF68G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 6 CAPACITANCE (pF) 4 2 SF61G - SF64G 100 SF65G - SF68G f=1.0MHz Vsig=50mVp-p 0 25 50 75 100 125 10 150 0.1 1 AMBIENT TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=125°C TJ=75°C 1 TJ=25°C 0.1 20 30 40 50 60 70 80 90 100 1010 SF61G - SF64G 1 UF1DLW SF65G - SF66G TJ=125°C TJ=25°C 10.1 SF67G - SF68G 0.01 0.1 0.001 0.3 0.5 0.7 0.3 0.4 0.5 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Pulse Pulse width width 300μs 300μs 1% Pulse width 1% duty duty cycle cycle 0.9 0.6 1.1 0.7 1.3 0.8 1.5 0.9 1.7 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 175 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (µA) Fig.4 Typical Forward Characteristics 100 10 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 10 10 (A) AVERAGE FORWARD CURRENT (A) 8 150 8.3ms single half sine wave 125 100 75 50 25 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: G2105 1.2 SF61G – SF68G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: G2105 SF61G – SF68G Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-201AD MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: G2105 SF61G – SF68G Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: G2105
SF62G R0G 价格&库存
很抱歉,暂时无法提供与“SF62G R0G”相匹配的价格&库存,您可以联系我们找货
