S1KFS MWG
S1KFS MWG
    TAIWANSEMICONDUCTOR(台湾半导体)
    SOD-128
S1KFS MWG 数据手册
S1DFS – S1MFS Taiwan Semiconductor 1A, 200V - 1000V Standard Surface Mount Rectifier FEATURES ● ● ● ● ● KEY PARAMETERS Glass passivated chip junction Ideal for automated placeme Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● DC to DC converter ● Switching mode converters and inverters ● General purpose PARAMETER VALUE UNIT IF 1 A VRRM 200 - 1000 V IFSM 30 A TJ MAX 150 °C Package SOD-128 Configuration Single die MECHANICAL DATA ● ● ● ● ● ● Case: SOD-128 Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.027g (approximately) SOD-128 ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device S1DFS S1GFS S1JFS S1KFS S1MFS UNIT S1DFS S1GFS S1JFS S1KFS S1MFS Repetitive peak reverse voltage VRRM 200 400 600 800 1000 V Reverse voltage, total rms value VR(RMS) 140 280 420 560 700 V Forward current Surge peak forward current, 8.3 ms single half sine-wave superimposed on rated load Junction temperature IF 1 A IFSM 30 A TJ -55 to +150 °C Storage temperature TSTG -55 to +150 °C 1 Version: C2103 S1DFS – S1MFS Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 29 °C/W Junction-to-ambient thermal resistance RӨJA 82 °C/W Junction-to-case thermal resistance RӨJC 30 °C/W Thermal Performance Note: Units mounted on PCB (5mm x 5mm Cu pad test board) ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL IF = 0.5A, TJ = 25°C Forward voltage IF = 1.0A, TJ = 25°C (1) IF = 0.5A, TJ = 125°C VF IF = 1.0A, TJ = 125°C Reverse current @ rated VR (2) Junction capacitance TJ = 25°C IR TJ = 125°C 1MHz, VR = 4.0V CJ TYP MAX UNIT 0.91 1.0 V 0.99 1.1 V 0.78 0.87 V 0.85 0.95 V - 1 µA - 50 µA 9 - pF Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING S1xFS SOD-128 14,000 / Tape & Reel Notes: 1. “x” defines voltage from 200V(S1DFS) to 1000V(S1MFS) 2 Version: C2103 S1DFS – S1MFS Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 100 CAPACITANCE (pF) 1 1 f=1.0MHz Vsig=50mVp-p 0.1 0 25 50 75 100 125 1 150 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics Fig.4 Typical Forward Characteristics 10 TJ=125°C 1 0.1 0.01 TJ=25°C 0.001 10 10 LEAD TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) 10 20 30 40 50 60 70 80 90 10 10 TJ=125°C TJ=125°C 1 TJ=25°C 0.1 TJ=25°C 0.01 Pulse width 0.001 0.3 0.1 0.6 100 UF1DLW 1 (A) AVERAGE FORWARD CURRENT (A) 2 0.7 0.4 0.8 0.5 0.6 0.9 1 0.7 1.1 Pulse width 300μs 1% duty 0.8 0.9 cycle 1 1.1 1.2 1.3 1.4 1.5 1.6 FORWARD VOLTAGE (V) PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 3 Version: C2103 1.2 S1DFS – S1MFS Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS SOD-128 SUGGESTED PAD LAYOUT MARKING DIAGRAM P/N = Marking Code YW = Date Code F = Factory Code 4 Version: C2103 S1DFS – S1MFS Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: C2103
S1KFS MWG 价格&库存
很抱歉,暂时无法提供与“S1KFS MWG”相匹配的价格&库存,您可以联系我们找货
S1KFS MWG
  • 3500+0.896073500+0.11640
  • 10500+0.7715310500+0.10022
库存:8390
S1KFS MWG
  • 1+4.238101+0.55051
  • 10+2.5866310+0.33599
  • 50+1.8662650+0.24242
  • 100+1.63322100+0.21215
  • 500+1.21985500+0.15846
库存:8390
