EABS1J REG
EABS1J REG
    TAIWANSEMICONDUCTOR(台湾半导体)
    SMD4
    BRIDGE RECT 1PHASE 600V 1A ABS
EABS1J REG 数据手册
EABS1D – EABS1J Taiwan Semiconductor 1A, 200V - 600V Super Fast Bridge Rectifier FEATURES ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Ideal for automated placement, for compact PCB design High surge current capability Super fast reverse recovery time for high frequency Negligible leakage current Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 1 A VRRM 200 - 600 V IFSM 40 A TJ MAX 150 °C Package ABS Configuration Quad APPLICATIONS ● Switching mode power supply (SMPS) ● Adapters ● Lighting application MECHANICAL DATA ● ● ● ● ● ● Case: ABS Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 0.090g (approximately) ABS ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device EABS1D EABS1G EABS1J EABS1D EABS1G EABS1J UNIT Repetitive peak reverse voltage VRRM 200 400 600 V Reverse voltage, total rms value VR(RMS) 140 280 420 V Forward current Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load Rating for fusing (t
EABS1J REG 价格&库存
很抱歉,暂时无法提供与“EABS1J REG”相匹配的价格&库存,您可以联系我们找货
