HS2AA – HS2MA
Taiwan Semiconductor
1.5A, 50V - 1000V High Efficient Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Glass passivated chip junction
Ideal for automated placement
Low profile package
Fast switching for high efficiency
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
1.5
A
VRRM
50 - 1000
V
IFSM
50
A
TJ MAX
150
°C
Package
DO-214AC (SMA)
Configuration
Single die
DC to DC converter
Switching mode converters and inverters
Lighting application
Snubber
Freewheeling application
MECHANICAL DATA
Case: DO-214AC (SMA)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.060g (approximately)
DO-214AC (SMA)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
HS
2AA
HS
2AA
HS
2BA
HS
2BA
HS
2DA
HS
2DA
HS
2FA
HS
2FA
HS
2GA
HS
2GA
HS
2JA
HS
2JA
HS
2KA
HS
2KA
VRRM
50
100
200
300
400
600
800
1000
V
VR(RMS)
35
70
140
210
280
420
560
700
V
SYMBOL
Marking code on the device
Repetitive peak reverse
voltage
Reverse voltage, total rms
value
Forward current
Peak forward surge current,
8.3ms single half sine-wave
superimposed on rated load
Junction temperature
Storage temperature
HS
UNIT
2MA
HS
2MA
IF
1.5
A
IFSM
50
A
TJ
- 55 to +150
°C
TSTG
- 55 to +150
°C
1
Version: J2102
HS2AA – HS2MA
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJA
80
°C/W
Junction-to-ambient thermal resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
HS2AA
HS2BA
HS2DA
HS2FA
HS2GA
HS2JA
HS2KA
HS2MA
(1)
Reverse current @ rated VR
TJ = 25°C
(2)
Junction capacitance
Reverse recovery time
IF = 1.5A, TJ = 25°C
VF
IR
TJ = 125°C
HS2AA
HS2BA
HS2DA
HS2FA
HS2GA
HS2JA
HS2KA
HS2MA
HS2AA
HS2BA
HS2DA
HS2FA
HS2GA
HS2JA
HS2KA
HS2MA
SYMBOL
1MHz, VR = 4.0V
IF = 0.5A, IR = 1.0A,
Irr = 0.25A
TYP
MAX
UNIT
1.0
V
1.3
V
1.7
V
5
µA
100
µA
50
pF
30
pF
50
ns
75
ns
CJ
trr
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
HS2xA
DO-214AC (SMA)
7,500 / Tape & Reel
Notes:
1. “x” defines voltage from 50V(HS2AA) to 1000V(HS2MA)
2
Version: J2102
HS2AA – HS2MA
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
125
100
1.5
CAPACITANCE (pF)
1.0
0.5
75
HS2AA - HS2GA
50
HS2JA - HS2MA
25
f=1.0MHz
Vsig=50mVp-p
25
50
75
100
125
0.1
150
1
LEAD TEMPERATURE ( °C)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=125°C
10
TJ=25°C
1
40
50
60
70
80
90
100
10 10
HS2AA - HS2FA
UF1DLW
1
TJ=125°C
TJ=25°C
HS2GA
10.1
HS2JA - HS2MA
0.01
0.1
0.001
0.6
0.3
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Pulse width 300μs
1% duty cycle
Pulse width
0.8
0.4
0.5
1.0
0.6
1.2
0.7
0.8
1.4
0.9
1.6
1
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
60
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (μA)
Fig.4 Typical Forward Characteristics
1000
10
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
100
10
(A)
AVERAGE FORWARD CURRENT (A)
2.0
8.3ms single half sine wave
50
40
30
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: J2102
1.2
HS2AA – HS2MA
Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram
4
Version: J2102
HS2AA – HS2MA
PACKAGE OUTLINE DIMENSIONS
DO-214AC (SMA)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Version: J2102
HS2AA – HS2MA
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: J2102
很抱歉,暂时无法提供与“HS2GA R3G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+4.86000
- 200+1.94400
- 500+1.87920
- 1000+1.84680
