2A01G – 2A07G
Taiwan Semiconductor
2A, 50V - 1000V Standard Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Glass passivated chip junction
High efficiency, Low VF
High current capability
High surge current capability
Low power loss
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
2
A
VRRM
50 - 1000
V
IFSM
70
A
TJ MAX
150
°C
Package
DO-204AC (DO-15)
Configuration
Single die
APPLICATIONS
● DC to DC converter
● Switching mode converters and inverters
● General purpose
MECHANICAL DATA
Case: DO-204AC (DO-15)
Molding compound meets UL 94V-0 flammability rating
Terminal: Pure tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.400g (approximately)
DO-204AC (DO-15)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL 2A01G 2A02G 2A03G 2A04G 2A05G 2A06G 2A07G UNIT
Marking code on the
device
Repetitive peak reverse
VRRM
50
100
200
400
600
800
1000
V
voltage
Reverse voltage, total rms
VR(RMS)
35
70
140
280
420
560
700
V
value
Forward current
IF
2
A
Surge peak forward
current, 8.3ms single half
IFSM
70
A
sine wave superimposed
on rated load
Junction temperature
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +150
1
°C
Version: I2105
2A01G – 2A07G
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance
RӨJL
25
°C/W
Junction-to-ambient thermal resistance
RӨJA
60
°C/W
Junction-to-case thermal resistance
RӨJC
22
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
2A01G
2A02G
2A03G
2A04G
2A05G
2A06G
2A07G
(1)
Reverse current @ rated VR
(2)
Junction capacitance
IF = 2A, TJ = 25°C
TJ = 25°C
SYMBOL
1MHz, VR = 4.0V
MAX
UNIT
1.1
V
1.0
V
5
µA
100
µA
15
pF
VF
IR
TJ = 125°C
TYP
CJ
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
2A0xG
DO-204AC (DO-15)
3,500 / Tape & Reel
2A0xG A0G
DO-204AC (DO-15)
1,500 / Ammo box
2A0xGH
DO-204AC (DO-15)
3,500 / Tape & Reel
2A0xGHA0G
DO-204AC (DO-15)
1,500 / Ammo box
Notes:
1. "x" defines voltage from 50V (2A01G) to 1000V (2A07G)
2. “H” means AEC-Q101 qualified
2
Version: I2105
2A01G – 2A07G
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
100
CAPACITANCE (pF)
2
1
10
f=1.0MHz
Vsig=50mVp-p
1
50
75
100
125
0.1
150
1
AMBIENT TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=125°C
TJ=75°C
0.1
TJ=25°C
0.01
10
40
50
60
70
80
90
100
1010
UF1DLW
1
2A01G-2A02G
TJ=125°C
TJ=25°C
10.1
2A03G-2A07G
0.01
0.1
0.001
0.60.3 0.7
0.4 0.8
0.5
Pulse
Pulse width
width 300μs
300μs
1% duty cycle
Pulse width
0.9
0.6
1
0.7
1.1
0.8
1.2
0.9
11.3
1.1
FORWARD VOLTAGE (V)
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Fig.5 Maximum Non-Repetitive Forward Surge Current
80
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (µA)
Fig.4 Typical Forward Characteristics
100
1
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
10
10
(A)
AVERAGE FORWARD CURRENT (A)
3
70
8.3ms single half sine wave
60
50
40
30
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: I2105
1.2
2A01G – 2A07G
PACKAGE OUTLINE DIMENSIONS
DO-204AC (DO-15)
MARKING DIAGRAM
4
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: I2105
2A01G – 2A07G
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
5
Version: I2105
很抱歉,暂时无法提供与“2A02GHB0G”相匹配的价格&库存,您可以联系我们找货
