SF805G C0G
SF805G C0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-220-3
    DIODE GEN PURP 300V 8A TO220AB
SF805G C0G 数据手册
SF801G – SF808G Taiwan Semiconductor 8A, 50V - 600V Super Fast Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available High efficiency, low VF High current capability High surge current capability Low power loss RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 8 A VRRM 50 - 600 V IFSM 125 A TJ MAX 150 °C APPLICATIONS Package TO-220AB Configuration Dual dies ● DC to DC converters ● Switching mode converters and inverters ● Freewheeling application MECHANICAL DATA ● ● ● ● ● ● ● Case: TO-220AB Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Mounting torque: 0.56 N⋅m maximum Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.82g (approximately) TO-220AB ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) SF SF SF SF SF SF SF SF PARAMETER SYMBOL UNIT 801G 802G 803G 804G 805G 806G 807G 808G SF SF SF SF SF SF SF SF Marking code on the device 801G 802G 803G 804G 805G 806G 807G 808G Repetitive peak reverse voltage VRRM 50 100 150 200 300 400 500 600 V Reverse voltage, total rms value VR(RMS) 35 70 105 140 210 280 350 420 V Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature IF 8 A IFSM 125 A TJ -55 to +150 °C Storage temperature TSTG -55 to +150 °C 1 Version: I2104 SF801G – SF808G Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER Junction-to-case thermal resistance SYMBOL TYP UNIT RӨJC 3 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SF801G SF802G SF803G SF804G (1) Forward voltage per diode I = 4A, TJ = 25°C SF805G F SF806G SF807G SF808G TJ = 25°C (2) Reverse current @ rated VR per diode TJ = 100°C SF801G SF802G SF803G SF804G Junction capacitance per diode 1MHz, VR = 4.0V SF805G SF806G SF807G SF808G IF = 0.5A, IR = 1.0A, Reverse recovery time Irr = 0.25A Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms SYMBOL TYP MAX UNIT - 0.975 V - 1.300 V - 1.700 V - 10 µA - 400 µA 70 - pF 50 - pF - 35 ns VF IR CJ trr ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING SF8xG TO-220AB 50 / Tube SF8xGH TO-220AB 50 / Tube Notes: 1. “x” defines voltage from 50V(SF801G) to 600V(SF808G) 2. “H” means AEC-Q101 qualified 2 Version: I2104 SF801G – SF808G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 100 90 8 CAPACITANCE (pF) 6 4 2 SF801G-804G 80 70 SF805G-808G 60 50 0 25 50 75 100 125 f=1.0MHz Vsig=50mVp-p 40 150 1 10 CASE TEMPERATURE (°C) Fig.4 Typical Forward Characteristics INSTANTANEOUS FORWARD CURRENT (A) 100 TJ=100°C 10 1 TJ=25°C 0.1 20 30 40 50 60 70 80 90 100 100 10 SF805G-806G 10 UF1DLW 1 SF801G-804G TJ=125°C TJ=25°C 0.1 1 SF807G-808G 0.01 Pulse width 300μs 1% duty cycle Pulse width 0.1 0.001 0.4 0.30.6 0.40.8 0.51.0 0.61.2 0.7 1.4 0.8 1.6 0.9 1.8 2.0 1 1.1 FORWARD VOLTAGE (V) PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Fig.5 Maximum Non-Repetitive Forward Surge Current 150 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (µA) Fig.3 Typical Reverse Characteristics 10 100 REVERSE VOLTAGE (V) (A) AVERAGE FORWARD CURRENT (A) 10 125 8.3ms single half sine wave 100 75 50 25 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: I2104 1.2 SF801G – SF808G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: I2104 SF801G – SF808G Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS TO-220AB MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: I2104 SF801G – SF808G Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: I2104
SF805G C0G 价格&库存
很抱歉,暂时无法提供与“SF805G C0G”相匹配的价格&库存,您可以联系我们找货
