GBLA10HD2G
GBLA10HD2G
    TAIWANSEMICONDUCTOR(台湾半导体)
    SIP4
    BRIDGE RECT 1PHASE 1KV 4A GBL
GBLA10HD2G 数据手册
GBLA005 – GBLA10 Taiwan Semiconductor 4A, 50V - 1000V Standard Bridge Rectifier FEATURES ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Glass passivated chip junction Ideal for printed circuit board High case dielectric strength Typical IR less than 0.1μA UL Recognized File # E-326243 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 4 A VRRM 50 - 1000 V IFSM 120 A TJ MAX 150 °C Package GBL Configuration Quad APPLICATIONS ● Switching mode power supply (SMPS) ● Adapters ● Lighting application MECHANICAL DATA ● ● ● ● ● ● Case: GBL Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 2.00g (approximately) GBL ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device Repetitive peak reverse voltage VRRM Reverse voltage, total rms value VR(RMS) 35 70 140 280 420 560 700 V 4 A 3 A IFSM 120 A It 2 59 As Junction temperature TJ - 55 to +150 °C Storage temperature TSTG - 55 to +150 °C Forward current TC = 50°C GBLA GBLA GBLA GBLA GBLA GBLA GBLA UNIT 005 01 02 04 06 08 10 GBLA GBLA GBLA GBLA GBLA GBLA GBLA 005 01 02 04 06 08 10 50 100 200 400 600 800 1000 V TA = 40°C Surge peak forward current, 8.3ms single half sine-wave superimposed on rated load Rating for fusing (t
GBLA10HD2G 价格&库存
很抱歉,暂时无法提供与“GBLA10HD2G”相匹配的价格&库存,您可以联系我们找货
