GBU604HD2G
GBU604HD2G
    TAIWANSEMICONDUCTOR(台湾半导体)
    SIP4
    BRIDGE RECT 1PHASE 400V 6A GBU
GBU604HD2G 数据手册
GBU601 – GBU607 Taiwan Semiconductor 6A, 50V - 1000V Standard Bridge Rectifier FEATURES ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Ideal for printed circuit board High case dielectric strength of 1500VRMS High surge current capability Typical IR less than 0.1μA UL Recognized File # E-326243 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 6 A VRRM 50 - 1000 V IFSM 175 A TJ MAX 150 °C Package GBU Configuration Quad APPLICATIONS ● Switching mode power supply (SMPS) ● Adapters ● Lighting application MECHANICAL DATA ● ● ● ● ● ● Case: GBU Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Mounting torque: 0.56 N⋅m maximum Polarity: As marked Weight: 4.00g (approximately) GBU ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) Repetitive peak reverse voltage VRRM GBU 601 GBU 601 50 Reverse voltage, total rms value VR(RMS) 35 PARAMETER SYMBOL Marking code on the device Forward current Surge peak forward current, 8.3ms single half sine-wave superimposed on rated load Rating for fusing (t
GBU604HD2G 价格&库存
很抱歉,暂时无法提供与“GBU604HD2G”相匹配的价格&库存,您可以联系我们找货
