RABS15MHRGG
RABS15MHRGG
    TAIWANSEMICONDUCTOR(台湾半导体)
    SMD4
    BRIDGE RECT 1P 1KV 1.5A ABS-L
RABS15MHRGG 数据手册
RABS15M Taiwan Semiconductor 1.5A, 1000V Fast Recovery Bridge Rectifier FEATURES ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Ideal for automated placement High surge current capability Fast reverse recovery time for high frequency Negligible leakage current Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 1.5 A VRRM 1000 V IFSM 50 A TJ MAX 150 °C Package ABS-L Configuration Quad APPLICATIONS ● Switching mode power supply (SMPS) ● Adapters ● Lighting application MECHANICAL DATA ● ● ● ● ● ● Case: ABS-L Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 0.090g (approximately) ABS-L ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device RABS15M UNIT RABS15M Repetitive peak reverse voltage VRRM 1000 V Reverse voltage, total rms value VR(RMS) 700 V IF 1.5 A IFSM 50 A It 2 10 As Junction temperature TJ -55 to +150 °C Storage temperature TSTG -55 to +150 °C Forward current Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load Rating for fusing (t
RABS15MHRGG 价格&库存
很抱歉,暂时无法提供与“RABS15MHRGG”相匹配的价格&库存,您可以联系我们找货
