NURS360BJ
NURS360BJ
    WEEN(瑞能)
    SMB(DO-214AA)
    DIODE GEN PURP 600V 3A SOD132
NURS360BJ 数据手册
SM B NURS360B Ultrafast power diode 30 August 2013 Product data sheet 1. General description Ultrafast power diode in a SOD132 (SMB) surface-mountable plastic package. 2. Features and benefits • • • • • Low on-state loss Low leakage current Low thermal resistance Surface-mountable package Reduces switching losses in associated MOSFET or IGBT 3. Applications • • • Buck and Boost converter Discontinuous Current Mode (DCM) Power Factor Correction (PFC) Inverter freewheeling and protection diode 4. Quick reference data Table 1. Quick reference data Symbol Parameter VRRM repetitive peak reverse voltage IF(AV) average forward current Conditions Min Typ Max Unit - - 600 V - - 3 A IF = 3 A; Tj = 150 °C; Fig. 7 - 0.8 1 V IF = 1 A; VR = 30 V; dIF/dt = 50 A/µs; - - 75 ns δ = 0.5 ; Tlead ≤ 115 °C; square-wave pulse; Fig. 1; Fig. 2; Fig. 3 Static characteristics VF forward voltage Dynamic characteristics trr reverse recovery time Tj = 25 °C; Ramp Recovery; Fig. 8 Scan or click this QR code to view the latest information for this product NURS360B NXP Semiconductors Ultrafast power diode 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 K 2 Simplified outline Graphic symbol cathode A K anode 1 2 A 001aaa020 SOD132 6. Ordering information Table 3. Ordering information Type number Package NURS360B Name Description Version SOD132 Hermetically sealed plastic package; SMB; 2 leads SOD132 7. Marking Table 4. Marking codes Type number Marking code NURS360B NURS360B 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VRRM Conditions Min Max Unit repetitive peak reverse voltage - 600 V VRWM crest working reverse voltage - 600 V VR reverse voltage DC - 600 V IF(AV) average forward current δ = 0.5 ; Tlead ≤ 115 °C; square-wave - 3 A pulse; Fig. 1; Fig. 2; Fig. 3 IFRM repetitive peak forward current δ = 0.5 ; tp = 25 µs; square-wave pulse - 6 A IFSM non-repetitive peak forward current tp = 10 ms; Tj(init) = 25 °C; sine-wave - 100 A - 110 A pulse; Fig. 4 tp = 8.3 ms; Tj(init) = 25 °C; sine-wave pulse; Fig. 4 Tstg storage temperature -65 175 °C Tj junction temperature - 175 °C NURS360B Product data sheet All information provided in this document is subject to legal disclaimers. 30 August 2013 © NXP N.V. 2013. All rights reserved 2/9 NURS360B NXP Semiconductors Ultrafast power diode 003aak951 5 Ptot (W) 003aak952 4 δ=1 Ptot (W) 4 a = 1.57 3 0.5 1.9 2.2 3 2.8 0.2 2 0.1 2 1 1 0 Fig. 1. 4.0 0 1 2 3 0 4 5 IF(AV) (A) Forward power dissipation as a function of average forward current; square waveform; maximum values Fig. 2. 003aak953 4 IF(AV) (A) 0 1 2 3 IF(AV) (A) Forward power dissipation as a function of average forward current; sinusoidal waveform; maximum values 003aak954 104 IFSM (A) 115 °C 3 103 2 102 IF IFSM 1 0 -50 Fig. 3. 0 50 100 150 Tl (°C) 10 10-5 200 Forward current as a function of lead temperature; maximum values Fig. 4. t tp Tj(init) = 25 °C max 10-4 10-3 10-2 tp (s) Non-repetitive peak forward current as a function of pulse width; sinusoidal waveform; maximum values 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-lead) thermal resistance from junction to lead mounted on a minimum footprint printed-circuit board (FR4); Fig. 5 - 14 - K/W NURS360B Product data sheet All information provided in this document is subject to legal disclaimers. 30 August 2013 © NXP N.V. 2013. All rights reserved 3/9 NURS360B NXP Semiconductors Ultrafast power diode Symbol Parameter Conditions Min Typ Max Unit Rth(j-a) thermal resistance from junction to ambient mounted on a minimum footprint printed-circuit board (FR4); Fig. 6 - 125 - K/W 003aak955 102 Zth(j-l) (K/W) 101 1 δ = 0.5 10-1 δ = 0.3 P δ = 0.1 δ = 0.05 10-2 tp T δ = 0.02 δ = 0.01 single pulse 10-3 10-6 Fig. 5. δ= 10-5 10-4 10-3 tp 10-2 10-1 1 t T 10 102 tp (s) Transient thermal impedance from junction to lead as a function of pulse duration; typical values 003aak956 103 Zth(j-a) (K/W) 102 101 1 δ = 0.5 δ = 0.3 10-1 P δ = 0.1 δ= δ = 0.05 T δ = 0.02 10-2 δ = 0.01 single pulse 10-3 10-6 Fig. 6. tp 10-5 10-4 10-3 10-2 tp 10-1 t T 101 1 tp (s) 102 Transient thermal impedance from junction to ambient as a function of pulse duration; typical values 10. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit IF = 3 A; Tj = 25 °C; Fig. 7 - - 1.25 V IF = 3 A; Tj = 150 °C; Fig. 7 - 0.8 1 V VR = 600 V; Tj = 25 °C - - 2.5 µA Static characteristics VF IR forward voltage reverse current NURS360B Product data sheet All information provided in this document is subject to legal disclaimers. 30 August 2013 © NXP N.V. 2013. All rights reserved 4/9 NURS360B NXP Semiconductors Ultrafast power diode Symbol Parameter Conditions Min Typ Max Unit VR = 600 V; Tj = 150 °C - - 250 µA IF = 1 A; VR = 30 V; dIF/dt = 50 A/µs; - - 75 ns - - 50 ns Dynamic characteristics trr reverse recovery time Tj = 25 °C; Ramp Recovery; Fig. 8 IF = 0.5 A; IR = 1 A; IR(meas) = 0.25 A; Tj = 25 °C; Step Recovery; Fig. 9 003aak957 6 IF dlF dt IF (A) trr 4 (1) (2) time (3) 25 % 2 IR 0 Fig. 7. 100 % Qr IRM 003aac562 0 0.5 1 1.5 VF (V) 2 Fig. 8. Reverse recovery definitions; ramp recovery Forward current as a function of forward voltage IF IF trr time 0.25 x IR Qr IR IR Fig. 9. 003aac563 Reverse recovery definitions; step recovery NURS360B Product data sheet All information provided in this document is subject to legal disclaimers. 30 August 2013 © NXP N.V. 2013. All rights reserved 5/9 NURS360B NXP Semiconductors Ultrafast power diode 11. Package outline SOD132 Hermetically sealed plastic package; SMB; 2 leads A C L A1 E1 E b 0 2.5 mm A A1 b c D 5 mm scale Dimensions (mm are the original dimensions) Unit D E E1 L max 2.45 0.20 2.20 0.41 3.95 4.60 5.60 1.60 nom min 1.90 0.05 1.95 0.15 3.30 4.05 5.10 0.75 sod132_po Outline version References IEC SOD132 JEDEC JEITA European projection Issue date 12-08-09 13-03-07 SMB. DO-214AA Fig. 10. Package outline SOD132 NURS360B Product data sheet All information provided in this document is subject to legal disclaimers. 30 August 2013 © NXP N.V. 2013. All rights reserved 6/9 NURS360B NXP Semiconductors Ultrafast power diode In no event shall NXP Semiconductors be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. 12. Legal information 12.1 Data sheet status Notwithstanding any damages that customer might incur for any reason whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of NXP Semiconductors. Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Definition Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 12.2 Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between NXP Semiconductors and its customer, unless NXP Semiconductors and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the NXP Semiconductors product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. NXP Semiconductors takes no responsibility for the content in this document if provided by an information source outside of NXP Semiconductors. NURS360B Product data sheet Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors and its suppliers accept no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using NXP Semiconductors products, and NXP Semiconductors accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the NXP Semiconductors product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. NXP Semiconductors does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using NXP Semiconductors products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). NXP does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. NXP Semiconductors hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of NXP Semiconductors products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the All information provided in this document is subject to legal disclaimers. 30 August 2013 © NXP N.V. 2013. All rights reserved 7/9 NURS360B NXP Semiconductors Ultrafast power diode grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific NXP Semiconductors product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. NXP Semiconductors accepts no liability for inclusion and/or use of nonautomotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without NXP Semiconductors’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond NXP Semiconductors’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies NXP Semiconductors for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond NXP Semiconductors’ standard warranty and NXP Semiconductors’ product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Adelante, Bitport, Bitsound, CoolFlux, CoReUse, DESFire, EZ-HV, FabKey, GreenChip, HiPerSmart, HITAG, I²C-bus logo, ICODE, I-CODE, ITEC, Labelution, MIFARE, MIFARE Plus, MIFARE Ultralight, MoReUse, QLPAK, Silicon Tuner, SiliconMAX, SmartXA, STARplug, TOPFET, TrenchMOS, TriMedia and UCODE — are trademarks of NXP B.V. HD Radio and HD Radio logo — are trademarks of iBiquity Digital Corporation. NURS360B Product data sheet All information provided in this document is subject to legal disclaimers. 30 August 2013 © NXP N.V. 2013. All rights reserved 8/9 NURS360B NXP Semiconductors Ultrafast power diode 13. Contents 1 General description ............................................... 1 2 Features and benefits ............................................1 3 Applications ........................................................... 1 4 Quick reference data ............................................. 1 5 Pinning information ............................................... 2 6 Ordering information ............................................. 2 7 Marking ................................................................... 2 8 Limiting values .......................................................2 9 Thermal characteristics .........................................3 10 Characteristics ....................................................... 4 11 Package outline ..................................................... 6 12 12.1 12.2 12.3 12.4 Legal information ...................................................7 Data sheet status ................................................. 7 Definitions .............................................................7 Disclaimers ...........................................................7 Trademarks .......................................................... 8 © NXP N.V. 2013. All rights reserved For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 30 August 2013 NURS360B Product data sheet All information provided in this document is subject to legal disclaimers. 30 August 2013 © NXP N.V. 2013. All rights reserved 9/9
NURS360BJ 价格&库存
很抱歉,暂时无法提供与“NURS360BJ”相匹配的价格&库存,您可以联系我们找货
