BA157G – BA159G
Taiwan Semiconductor
1A, 400V - 1000V Fast Recovery Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Glass passivated chip junction
High current capability, Low VF
High reliability
High surge current capability
Low power loss, high efficiency
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
1
A
VRRM
400 - 1000
V
IFSM
30
A
TJ MAX
150
°C
Package
DO-204AL (DO-41)
Configuration
Single die
APPLICATIONS
● DC to DC converter
● Switching mode converters and inverters
● General purpose
MECHANICAL DATA
Case: DO-204AL (DO-41)
Molding compound meets UL 94V-0 flammability rating
Terminal: Pure tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.330g (approximately)
DO-204AL (DO-41)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
BA157G
BA158G
BA159G
BA157G
BA158G
BA159G
UNIT
Repetitive peak reverse voltage
VRRM
400
600
1000
V
Reverse voltage, total rms value
VR(RMS)
280
420
700
V
Forward current
Surge peak forward current, 8.3ms single
half sine wave superimposed on rated load
Junction temperature
IF
1
A
IFSM
30
A
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +150
°C
1
Version: I2106
BA157G – BA159G
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJA
60
°C/W
Junction-to-ambient thermal resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
(1)
Reverse current @ rated VR
IF = 1A, TJ = 25°C
TJ = 25°C
(2)
Reverse recovery time
BA157G
BA158G
BA159G
TYP
MAX
UNIT
VF
1.2
V
5
µA
100
µA
15
pF
150
ns
250
ns
IR
TJ = 125°C
Junction capacitance
SYMBOL
1MHz, VR = 4.0V
CJ
IF = 0.5A, IR = 1.0A,
Irr = 0.25A
trr
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
BA15xG
DO-204AL (DO-41)
5,000 / Tape & Reel
BA15xG A0G
DO-204AL (DO-41)
3,000 / Ammo box
BA15xGH
DO-204AL (DO-41)
5,000 / Tape & Reel
BA15xGHA0G
DO-204AL (DO-41)
3,000 / Ammo box
Notes:
1. “x” defines voltage from 400V (BA157G) to 1000V (BA159G)
2. “H” means AEC-Q101 qualified
2
Version: I2106
BA157G – BA159G
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
100
CAPACITANCE (pF)
1
10
f=1.0MHz
Vsig=50mVp-p
1
50
75
100
125
1
150
10
AMBIENT TEMPERATURE (°C)
REVERSE VOLTAGE (V)
Fig.4 Typical Forward Characteristics
INSTANTANEOUS FORWARD CURRENT (A)
100
TJ=125°C
TJ=75°C
1
TJ=25°C
0.1
10
40
50
60
70
80
90
100
1010
UF1DLW
1
TJ=125°C
TJ=25°C
10.1
0.01
0.1
0.001
0.6
0.3
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Pulse width 300μs
1% duty cycle
Pulse width
0.8
0.4
0.5
1.0
0.6
1.2
0.7
0.8
1.4
0.9
1.6
1
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
35
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (µA)
Fig.3 Typical Reverse Characteristics
10
100
(A)
AVERAGE FORWARD CURRENT (A)
2
30
8.3ms single half sine wave
25
10
5
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: I2106
1.2
BA157G – BA159G
Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram
4
Version: I2106
BA157G – BA159G
PACKAGE OUTLINE DIMENSIONS
DO-204AL (DO-41)
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: I2106
BA157G – BA159G
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: I2106
很抱歉,暂时无法提供与“BA159GHB0G”相匹配的价格&库存,您可以联系我们找货
