FR157G B0G
FR157G B0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-204AC
    DIODE GEN PURP 1.5A DO204AC
FR157G B0G 数据手册
FR151G – FR157G Taiwan Semiconductor 1.5A, 50V - 1000V Fast Recovery Rectifier FEATURES ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Glass passivated chip junction High efficiency, Low VF High current capability High surge current capability Low power loss RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 1.5 A VRRM 50 - 1000 V IFSM 50 A TJ MAX 150 °C Package DO-204AC (DO-15) Configuration Single die APPLICATIONS ● DC to DC converter ● Switching mode converters and inverters ● General purpose MECHANICAL DATA ● ● ● ● ● ● Case: DO-204AC (DO-15) Molding compound meets UL 94V-0 flammability rating Terminal: Pure tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.400g (approximately) DO-204AC (DO-15) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Marking code on the device Repetitive peak reverse voltage Reverse voltage, total rms value Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature Storage temperature FR 151G FR 151G FR 152G FR 152G FR 153G FR 153G FR 154G FR 154G FR 155G FR 155G FR 156G FR 156G VRRM 50 100 200 400 600 800 1000 V VR(RMS) 35 70 140 280 420 560 700 V SYMBOL FR UNIT 157G FR 157G IF 1.5 A IFSM 50 A TJ -55 to +150 °C TSTG -55 to +150 °C 1 Version: I2105 FR151G – FR157G Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJA 60 °C/W Junction-to-ambient thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS (1) Reverse current @ rated VR IF = 1.5A, TJ = 25°C TJ = 25°C (2) Junction capacitance Reverse recovery time SYMBOL TYP MAX UNIT VF - 1.3 V - 5 µA - 100 µA 20 - pF - 150 ns - 250 ns - 500 ns IR TJ = 125°C 1MHz, VR = 4.0V FR151G FR152G FR153G FR154G IF = 0.5A, IR = 1.0A, I = 0.25A FR155G rr FR156G FR157G CJ trr Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING FR15xG DO-204AC (DO-15) 3,500 / Tape & Reel FR15xG A0G DO-204AC (DO-15) 1,500 / Ammo box FR15xGH DO-204AC (DO-15) 3,500 / Tape & Reel FR15xGHA0G DO-204AC (DO-15) 1,500 / Ammo box Notes: 1. "x" defines voltage from 50V (FR151G) to 1000V (FR157G) 2. “H” means AEC-Q101 qualified 2 Version: I2105 FR151G – FR157G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 100 1.5 CAPACITANCE (pF) 1 0.5 10 f=1.0MHz Vsig=50mVp-p 1 0 25 50 75 100 125 1 150 10 AMBIENT TEMPERATURE (°C) REVERSE VOLTAGE (V) Fig.4 Typical Forward Characteristics INSTANTANEOUS FORWARD CURRENT (A) 100 TJ=125°C 10 TJ=75°C 1 TJ=25°C 0.1 20 30 40 50 60 70 80 90 100 1010 UF1DLW 1 TJ=125°C TJ=25°C 10.1 0.01 0.1 0.001 0.70.3 Pulse Pulse width width 300μs 300μs 1% duty cycle Pulse width 0.9 0.4 0.5 1.10.6 1.3 0.7 0.8 1.50.9 11.7 1.1 FORWARD VOLTAGE (V) PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Fig.5 Maximum Non-Repetitive Forward Surge Current 60 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (µA) Fig.3 Typical Reverse Characteristics 10 100 (A) AVERAGE FORWARD CURRENT (A) 2 8.3ms single half sine wave 50 40 30 20 10 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: I2105 1.2 FR151G – FR157G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: I2105 FR151G – FR157G Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-204AC (DO-15) MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: I2105 FR151G – FR157G Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: I2105
FR157G B0G
物料型号:FR151G至FR157G 器件简介:这些是1.5A,50V至1000V的快速恢复整流器,具有AEC-Q101认证,玻璃钝化芯片,高效率,低正向电压降,高电流能力,高浪涌电流能力,低功耗,符合RoHS标准,无卤素。
引脚分配:文档中未明确列出引脚分配,但通常整流器有两个引脚,阳极和阴极。
参数特性:包括正向电流IF为1.5A,反向峰值电压VRRM从50V至1000V不等,浪涌峰值电流IFSM为50A,最大结温TJMAX为150℃。
功能详解:文档提供了热性能、电气规格和特性曲线,包括结到环境的热阻ReJA,正向电压VF,反向电流IR,结电容CJ和反向恢复时间tr。
应用信息:适用于DC到DC转换器、开关模式转换器和逆变器以及一般用途。
封装信息:封装类型为DO-204AC(DO-15),重量约为0.400g,符合UL 94V-0阻燃等级,终端为纯锡镀层引线。
订购信息:提供了不同电压等级和包装类型的订购代码。
特性曲线:包括正向电流降额曲线、典型结电容、典型反向特性、典型正向特性和最大非重复正向浪涌电流。
包装尺寸:提供了DO-204AC(DO-15)封装的尺寸图。
FR157G B0G 价格&库存
很抱歉,暂时无法提供与“FR157G B0G”相匹配的价格&库存,您可以联系我们找货
