SF3003PTHC0G
SF3003PTHC0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO247
    DIODE GEN PURP 150V 30A TO247AD
SF3003PTHC0G 数据手册
SF3001PT – SF3008PT Taiwan Semiconductor 30A, 50V - 600V Super Fast Rectifier FEATURES ● ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Dual rectifier construction, positive center-tap Glass passivated chip junctions Superfast recovery time, high voltage Low forward voltage, high current capability Low thermal resistance Low power loss, high efficiency RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 30 A VRRM 50 - 600 V IFSM 300 A TJ MAX 150 °C Package TO-247AD (TO-3P) Configuration Dual dies APPLICATIONS ● ● ● ● ● DC to DC converter Switching mode converters and inverters Lighting application Snubber Freewheeling application MECHANICAL DATA ● ● ● ● ● ● ● Case: TO-247AD (TO-3P) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 301 class 2 whisker test Mounting torque: 1.13 N⋅m maximum Polarity: As marked Weight: 5.60g (approximately) TO-247AD (TO-3P) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device Repetitive peak reverse voltage VRRM Reverse voltage, total rms value VR(RMS) SF SF 3001 3002 PT PT SF SF 3001 3002 PT PT 50 100 35 70 SF 3003 PT SF 3003 PT 150 105 SF SF 3004 3005 PT PT SF SF 3004 3005 PT PT 200 300 140 210 SF SF 3006 3008 UNIT PT PT SF SF 3006 3008 PT PT 400 600 V 280 420 V Forward current Surge peak forward current 8.3ms single half sine wave superimposed on rated load Junction temperature IF 30 A IFSM 300 A TJ -55 to +150 °C Storage temperature TSTG -55 to +150 °C 1 Version: J2103 SF3001PT – SF3008PT Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJC 1 °C/W Junction-to-case thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage per diode CONDITIONS (1) SF3001PT SF3002PT SF3003PT SF3004PT SF3005PT SF3006PT SF3008PT Reverse current @ rated VR per diode Junction capacitance per diode Reverse recovery time (2) IF = 15A, TJ = 25°C TJ = 25°C TJ = 125°C 1MHz, VR = 4.0V IF = 0.5A, IR = 1.0A Irr = 0.25A SYMBOL TYP MAX UNIT - 0.95 V - 1.30 V - 1.70 V - 10 µA - 500 µA CJ 175 - pF trr - 35 ns VF IR Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING SF30xPT TO-247AD (TO-3P) 30 / Tube SF30xPTH TO-247AD (TO-3P) 30 / Tube Notes: 1. “x” defines voltage from 50V(SF3001PT) to 600V(SF3008PT) 2. “H” means AEC-Q101 qualified 2 Version: J2103 SF3001PT – SF3008PT Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 30 25 CAPACITANCE (pF) 20 15 10 100 5 f=1.0MHz Vsig=50mVp-p 10 0 25 50 75 100 125 0.1 150 1 CASE TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) 100 TJ=100°C 10 TJ=75°C 1 TJ=25°C 0.1 30 40 50 60 70 80 90 100 100010 SF3001PT - SF3004PT SF3005PT - SF3008PT UF1DLW 100 1 TJ=125°C TJ=125°C 10 0.1 1 0.01 TJ=25°C TJ=25°C Pulse width 300μs 1% duty cycle Pulse width 0.1 0.001 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 0.3 0.4 0.5 0.6 0.7 0.8 0.9 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 1.8 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 330 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) Fig.4 Typical Forward Characteristics 1000 20 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 10 10 300 8.3ms single half sine wave 270 240 210 180 150 120 90 60 30 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 (A) AVERAGE FORWARD CURRENT (A) 35 Version: J2103 1.2 SF3001PT – SF3008PT Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: J2103 SF3001PT – SF3008PT Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS TO-247AD (TO-3P) MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: J2103 SF3001PT – SF3008PT Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: J2103
SF3003PTHC0G 价格&库存
很抱歉,暂时无法提供与“SF3003PTHC0G”相匹配的价格&库存,您可以联系我们找货
