SS210L RQG
SS210L RQG
    TAIWANSEMICONDUCTOR(台湾半导体)
    Sub-SMA
    DIODE SCHOTTKY 100V 2A SUB SMA
SS210L RQG 数据手册
SS22L – SS215L Taiwan Semiconductor 2A, 20V - 150V Schottky Barrier Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Low power loss, high efficiency Ideal for automated placement Guard ring for overvoltage protection High surge current capability Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 2 A VRRM 20 - 150 V IFSM 50 A TJ MAX 125, 150 °C APPLICATIONS Package Sub SMA Configuration Single die ● Switching mode power supply (SMPS) ● Adapters ● DC to DC converters MECHANICAL DATA ● ● ● ● ● ● Case: Sub SMA Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.019g (approximately) Sub SMA ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device SS 22L SS 23L SS 24L SS 25L SS 26L SS SS SS UNIT 29L 210L 215L 22L 23L 24L 25L 26L 29L 20L 2AL Repetitive peak reverse voltage VRRM 20 30 40 50 60 90 100 150 V Reverse voltage, total rms value VR(RMS) 14 21 28 35 42 63 70 105 V Forward current Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load Critical rate of rise of off-state voltage Junction temperature Storage temperature IF 2 A IFSM 50 A dv/dt 10,000 V/μs TJ - 55 to +125 TSTG - 55 to +150 - 55 to +150 1 °C °C Version: O2103 SS22L – SS215L Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 17 °C/W Junction-to-ambient thermal resistance RӨJA 75 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS (1) Reverse current @ rated VR (2) SS22L SS23L SS24L SS25L SS26L SS29L SS210L SS215L SS22L SS23L SS24L SS25L SS26L SS29L SS210L SS215L SS22L SS23L SS24L SS25L SS26L SS29L SS210L SS215L SS22L SS23L SS24L SS25L SS26L SS29L SS210L SS215L IF = 2A, TJ = 25°C SYMBOL VF TYP MAX UNIT - 0.50 V - 0.70 V - 0.85 V - 0.95 V - 400 µA - 100 µA - 15 mA - 10 mA - - mA - - mA - - mA - 5 mA TJ = 25°C TJ = 100°C IR TJ = 125°C Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING SS2xL Sub SMA 10,000 / Tape & Reel Notes: 1. “x” defines voltage from 20V(SS22L) to 150V(SS215L) 2 Version: O2103 SS22L – SS215L Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 SS25L - SS215L CAPACITANCE (pF) 2 1 SS22L - SS24L 100 10 f=1.0MHz Vsig=50mVp-p 1 0 25 50 75 100 125 0.1 150 1 LEAD TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=125°C 1 TJ=75°C 0.1 TJ=25°C 0.01 0.001 10 20 30 40 50 60 70 80 90 100 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 10 10 1 SS22L - SS24L UF1DLW SS25L - SS26L TJ=125°C 1 0.1 TJ=25°C SS29L - SS210L SS215L 0.01 0.1 0.001 0.2 0.4 0.3 0.4 Pulse width 300μs 1% duty cycle Pulse width 0.6 0.5 0.8 1.0 0.6 0.7 0.8 FORWARD VOLTAGE (V) 1.2 0.9 1.4 1 1.1 Fig.5 Maximum Non-Repetitive Forward Surge Current 60 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.4 Typical Forward Characteristics 100 10 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics SS22L - SS24L SS25L - SS215L 10 (A) AVERAGE FORWARD CURRENT (A) 3 8.3ms single half sine wave 50 40 30 20 10 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: O2103 1.2 SS22L – SS215L Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Typical Transient Thermal Impedance TRANSIENT THERMAL IMPEDANCE (°C/W) 100 10 1 0.1 0.01 0.1 1 10 100 PULSE DURATION (s) 4 Version: O2103 SS22L – SS215L Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS Sub SMA SUGGESTED PAD LAYOUT MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YW = Date Code F = Factory Code Version: O2103 SS22L – SS215L Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: O2103
SS210L RQG 价格&库存
很抱歉,暂时无法提供与“SS210L RQG”相匹配的价格&库存,您可以联系我们找货
