HERAF802G C0G
HERAF802G C0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-220-2
    DIODE GEN PURP 100V 8A ITO220AC
HERAF802G C0G 数据手册
HERAF801G – HERAF808G Taiwan Semiconductor 8A, 50V - 1000V High Efficient Rectifier FEATURES ● ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Glass passivated chip junction High efficiency, Low VF High current capability High reliability High surge current capability UL Recognized File # E-326243 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 8 A VRRM 50 - 1000 V IFSM 150 A TJ MAX 150 °C Package ITO-220AC Configuration Single die APPLICATIONS ● DC to DC converter ● Switching mode converters and inverters ● Freewheeling application MECHANICAL DATA ● ● ● ● ● ● ● Case: ITO-220AC Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Mounting torque: 0.56 N⋅m maximum Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.70g (approximately) ITO-220AC ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Marking code on the device Repetitive peak reverse voltage Reverse voltage total rms value Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature Storage temperature SYMBOL HERAF HERAF HERAF HERAF HERAF HERAF HERAF HERAF UNIT 801G 802G 803G 804G 805G 806G 807G 808G HERAF HERAF HERAF HERAF HERAF HERAF HERAF HERAF 801G 802G 803G 804G 805G 806G 807G 808G VRRM 50 100 200 300 400 600 800 1000 V VR(RMS) 35 70 140 210 280 420 560 700 V IF 8 A IFSM 150 A TJ -55 to +150 °C TSTG -55 to +150 °C 1 Version: K2105 HERAF801G – HERAF808G Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJC 2 °C/W Junction-to-case resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage (1) Reverse current @ rated VR (2) Junction capacitance Reverse recovery time CONDITIONS HERAF801G HERAF802G HERAF803G HERAF804G I = 8A, TJ = 25°C HERAF805G F HERAF806G HERAF807G HERAF808G TJ = 25°C SYMBOL TJ = 125°C HERAF801G HERAF802G HERAF803G HERAF804G 1MHz, VR = 4.0V HERAF805G HERAF806G HERAF807G HERAF808G HERAF801G HERAF802G HERAF803G HERAF804G IF = 0.5A, IR = 1.0A HERAF805G Irr = 0.25A HERAF806G HERAF807G HERAF808G VF IR TYP MAX UNIT - 1.0 V - 1.3 V - 1.7 V - 10 µA - 400 µA 80 - pF 60 - pF - 50 ns - 80 ns CJ trr Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING HERAF8xG ITO-220AC 50 / Tube HERAF8xGH ITO-220AC 50 / Tube Notes: 1. “x” defines voltage from 50V(HERAF801G) to 1000V(HERAF808G) 2. “H” means AEC-Q101 qualified 2 Version: K2105 HERAF801G – HERAF808G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 8 CAPACITANCE (pF) 6 4 HERAF801G-805G 100 HERAF806G-808G 10 2 f=1.0MHz Vsig=50mVp-p 1 0 25 50 75 100 125 1 150 10 CASE TEMPERATURE (°C) REVERSE VOLTAGE (V) Fig.4 Typical Forward Characteristics INSTANTANEOUS FORWARD CURRENT (A) 100 TJ=125°C 10 TJ=75°C 1 TJ=25°C 0.1 20 30 40 50 60 70 80 90 100 100 10 1 UF1DLW HERAF801G-804G 10 TJ=125°C TJ=25°C 0.1 HERAF805G 1 0.01 HERAF806G-808G 0.001 0.1 0.5 0.40.3 0.60.4 0.8 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Pulse width 300μs Pulse width 1% duty cycle 0.6 1 0.7 1.2 0.8 1.4 0.9 1.6 11.8 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 180 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) Fig.3 Typical Reverse Characteristics 10 100 (A) AVERAGE FORWARD CURRENT (A) 10 150 120 90 60 30 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: K2105 1.2 HERAF801G – HERAF808G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: K2105 HERAF801G – HERAF808G Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS ITO-220AC MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: K2105 HERAF801G – HERAF808G Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: K2105
HERAF802G C0G 价格&库存
很抱歉,暂时无法提供与“HERAF802G C0G”相匹配的价格&库存,您可以联系我们找货
