SF1001G – SF1008G
Taiwan Semiconductor
10A, 50V - 600V Super Fast Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
High efficiency, low VF
High current capability
High surge current capability
Low power loss
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
10
A
VRRM
50 - 600
V
IFSM
125
A
TJ MAX
150
°C
Package
TO-220AB
Configuration
Dual dies
● DC to DC converters
● Switching mode converters and inverters
● Freewheeling application
MECHANICAL DATA
Case: TO-220AB
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Mounting torque: 0.56 N⋅m maximum
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.82g (approximately)
TO-220AB
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
SF
SF
SF
SF
SF
SF
SF
SF
PARAMETER
SYMBOL
UNIT
1001G 1002G 1003G 1004G 1005G 1006G 1007G 1008G
Marking code on the
SF
SF
SF
SF
SF
SF
SF
SF
device
Repetitive peak
VRRM
50
100
150
200
300
400
500
600
V
reverse voltage
Reverse voltage, total
VR(RMS)
35
70
105
140
210
280
350
420
V
rms value
Forward current
IF
10
A
Surge peak forward
current, 8.3ms single
half sine wave
IFSM
125
A
superimposed on rated
load
Junction temperature
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +150
1
°C
Version: K2104
SF1001G – SF1008G
THERMAL PERFORMANCE
PARAMETER
Junction-to-case thermal resistance
SYMBOL
TYP
UNIT
RӨJC
3.5
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SF1001G
SF1002G
SF1003G
SF1004G
(1)
Forward voltage per diode
I = 5A, TJ = 25°C
SF1005G F
SF1006G
SF1007G
SF1008G
TJ = 25°C
(2)
Reverse current @ rated VR per diode
TJ = 100°C
SF1001G
SF1002G
SF1003G
SF1004G
Junction capacitance per diode
1MHz, VR = 4.0V
SF1005G
SF1006G
SF1007G
SF1008G
IF = 0.5A, IR = 1.0A,
Reverse recovery time
Irr = 0.25A
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
SYMBOL
TYP
MAX
UNIT
0.975
V
1.300
V
1.700
V
10
µA
400
µA
70
pF
50
pF
35
ns
VF
IR
CJ
trr
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
SF10xG
TO-220AB
50 / Tube
SF10xGH
TO-220AB
50 / Tube
Notes:
1. “x” defines voltage from 50V(SF1001G) to 600V(SF1008G)
2. “H” means AEC-Q101 qualified
2
Version: K2104
SF1001G – SF1008G
CHARACTERISTICS CURVES
Fig.2 Typical Junction Capacitance
12
100
10
90
CAPACITANCE (pF)
8
6
4
2
SF1001G-1004G
80
70
SF1005G-1008G
60
50
f=1.0MHz
Vsig=50mVp-p
40
25
50
75
100
125
150
1
10
CASE TEMPERATURE (°C)
Fig.4 Typical Forward Characteristics
INSTANTANEOUS FORWARD CURRENT (A)
100
TJ=100°C
10
TJ=75°C
1
TJ=25°C
0.1
40
50
60
70
80
90
100
100 10
SF1001G-1004G
UF1DLW
1 SF1005G-1006G
10
TJ=125°C
TJ=25°C
0.1
1
SF1007G-1008G
0.01
Pulse width 300μs
1% duty cycle
Pulse width
0.1
0.001
0.4 0.30.6 0.40.8 0.51.0 0.61.2 0.7
1.4 0.8
1.6 0.9
1.8
2.0
1
1.1
FORWARD VOLTAGE (V)
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Fig.5 Maximum Non-Repetitive Forward Surge Current
150
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (µA)
Fig.3 Typical Reverse Characteristics
10
100
REVERSE VOLTAGE (V)
(A)
AVERAGE FORWARD CURRENT (A)
Fig.1 Forward Current Derating Curve
125
8.3ms single half sine wave
100
75
50
25
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: K2104
1.2
SF1001G – SF1008G
Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram
4
Version: K2104
SF1001G – SF1008G
PACKAGE OUTLINE DIMENSIONS
TO-220AB
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: K2104
SF1001G – SF1008G
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: K2104
很抱歉,暂时无法提供与“SF1001G C0G”相匹配的价格&库存,您可以联系我们找货
